ball joints help
Old Oct 16, 2006 | 07:00 PM
lsvtechatch92's Avatar
Default ball joints help
trying to put the a arm back on and the freaking ball joint is spinning and i dont have the time nor the money to replace anyone know how to get around this
Old Oct 16, 2006 | 07:54 PM
EG2Driver's Avatar
Default Re: ball joints help (lsvtechatch92)
its 27 bucks from autozone.....i cut the nut off mine as it kept spinning. You might get away with putting pressure on the balljoint and trying to undo it....or use air.
Old Oct 17, 2006 | 08:00 AM
DeDonDeRosa's Avatar
Default Re: ball joints help (DeadEnd9009)
try to some how use a clamp and clamp it so theres pressure on the joint then use the impact comes off every time!!!
Old Oct 17, 2006 | 12:13 PM
Default Re: ball joints help (DeDonDeRosa)
trying to put back on
Old Oct 17, 2006 | 04:42 PM
97grnrs's Avatar
i guess u mean the lower ball joint.. if so put a jack under the control arm and support the whole cars weigh on the arm that connects to the joint .. it will stop spinning if u do it right..
mr.tatertits
Suspension & Brakes
Feb 27, 2016 05:42 AM
InTheZoneAC
Suspension & Brakes
19
Jan 22, 2014 05:21 AM
kornkid21792
Jan 27, 2010 08:12 PM
M15
Jan 19, 2007 02:44 PM
miksew
Sep 20, 2003 08:09 AM
