EGR wiring Harness
Ok guys i just bought an h22a4 swapped ek hatch. the car is from maryland so im not sure on hoe the emissions and inspection work over there. I live in pennsylvania. my problem is i dont think i will pass PA emissions. my car is scheldules for next tuesday. the car is running a p72 ecu. im guessing its chipped because there is no plug connected to the EGR valve and im not throwing any codes.
so if anyone can help me find where the wiring plug is so i can atleast plug it in to try and pass visual inspection on my car.
i will get a picture in a minute
probably not throwing a code cuz the ecu isn't looking for it. if you're concerned about passing smog, i'd get a pretest done first to see what your numbers look like then block it off if you're passing.
B_Swapped93
Mar 7, 2014 04:54 PM
MidnightWarrior
Feb 11, 2014 11:37 PM
