to hone or not to hone
Old Oct 16, 2006 | 11:34 AM
Boomer234's Avatar
Default to hone or not to hone
i have a '00 Si and i picked up some CTR pistons with rings (both new) and i was going to put them in my b16 but was wondering if you need to get a hone even if the block has been running and never taken apart?
i was under the impression that a hone only had to be done if a block was taken apart then sat for a while but just want to make sure, thanks for any input
Old Oct 16, 2006 | 11:54 AM
allmotorcrx2001's Avatar
Default Re: to hone or not to hone (Boomer234)
I will give it a slight hone especially if you putting new rings
Old Oct 16, 2006 | 12:59 PM
tha_badguy's Avatar
im no expert but never being open has nothing to do with whether or not you have to re-hone the cylinder walls
if u can still see the factory cross-hatching & there isnt any damage to the walls than ur good
Old Oct 16, 2006 | 01:57 PM
91SiZ6's Avatar
I'd rehone for proper ring seating. Even if the factory cross hatch is still there it isn't rough enough to file the rings properly.
Old Oct 16, 2006 | 02:48 PM
H24A96EK's Avatar
re-hone! new rings won't break in without it. you can pull an enging apart after 100k and still see crosshatching, but it doesn't mean that the new rings will seat with that.
Old Oct 16, 2006 | 03:18 PM
tha_badguy's Avatar
Default Re: (H24A96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H24A96EK &raquo;</TD></TR><TR><TD CLASS="quote">re-hone! new rings won't break in without it. you can pull an enging apart after 100k and still see crosshatching, but it doesn't mean that the new rings will seat with that.</TD></TR></TABLE>
you guys must not have seen the omniman 200hp b16...
Old Oct 16, 2006 | 03:27 PM
mmuller's Avatar
Mad Scientist
Default Re: (tha_badguy)
i would check for egg shaping first.
new rings can be put on onld cylinders if thecrosshatch is still very visible with no flat spots. wich is rare
Old Oct 16, 2006 | 07:16 PM
Boomer234's Avatar
thanks for the replies
chrisbigmouth
Dec 7, 2008 04:23 PM
KingOfQB
10
Mar 4, 2006 07:30 AM
xteg95
May 3, 2003 04:16 PM
xteg95
May 3, 2003 10:56 AM
