H22 wiring into 1998 EK civic 4 door
I didn't post this in the other H22/Question threads because I want to be able to keep track of it. Sorry mods, if you feel like this needs to be deleted please do so.
I NEED some wiring information for a OBD1 H22A (using the P13 ECU, will go to P28 later) into a 98 (OBD2) EK Civic.
I have extended the alternator wires, started to do the distributor, and I have wired the injectors.
I need the info for the IVAC, EGR, reverse, VSS, and whatever else I will need. Also-Some connector-to-motor sensor pics would be appricieated, as, I was in a hurry to pull both motors out of both cars and don't know where most of them go. I am wiring the motor up out of the car.
I am in need of this information ASAP. We are moving in about a week, and this motor must be in the car by then.
For the egr, DOnt even bother hooking it up, make yourself a block of plate, As for the VSS and the IVAC, match the colors, Theres a huge h22 faq , I gaurantee all your questions can be answerd in there.
IN the nearly 1,000 pages of posts?m I would hope so. Im just not gonna be the one to look trough every page of it.
I'll try searching again, but probabally wont get anywhere.
Thanks for the info.
