horn stopped working. checked fuse '1995-EG'
Old Oct 15, 2006 | 11:02 AM
dem0nk1d's Avatar
Default horn stopped working. checked fuse '1995-EG'
check voltage. nothing.... checked fuse under hood it's fine. does the horn wires go thru the srs harness, that's super flat/
Old Oct 15, 2006 | 11:27 AM
turtleman321's Avatar
bump friend needs to know also. he ordered an airbag reel. will try to let you know when he puts it in
Old Oct 15, 2006 | 11:38 AM
dem0nk1d's Avatar
Default Re: (turtleman321)
how did it break? or how can you tell it's broken.
Old Oct 15, 2006 | 01:03 PM
deryck324's Avatar
i have a similar problem , when i push the horn button the relay just clicks . can anyone help us
Old Oct 15, 2006 | 04:06 PM
dem0nk1d's Avatar
Default Re: (deryck324)
This might help us all....
https://honda-tech.com/zerothread?id=1337710
Old Oct 15, 2006 | 07:47 PM
deryck324's Avatar
well hears another issue my srs light comes on
Old Oct 15, 2006 | 07:54 PM
hatch96y7's Avatar
the **** spring went bad u have to replace that in oreder for ur horn and airbags to work
Old Oct 15, 2006 | 10:14 PM
dem0nk1d's Avatar
Default Re: (hatch96y7)
so the **** spring is the reel? or is it inside the reel?
Old Oct 16, 2006 | 12:24 PM
hatch96y7's Avatar
Default Re: (dem0nk1d)
typo CLOCK spring
Old Oct 16, 2006 | 12:30 PM
dem0nk1d's Avatar
well??? is the c"l"ock spring another name for "SRS-REEL". Or is it inside the SRS-REEL.
Old Oct 16, 2006 | 03:38 PM
hatch96y7's Avatar
its another name
Ryanb525
Jul 27, 2014 12:17 AM
black99x
Nov 19, 2009 05:18 AM
ridin98civic
Oct 16, 2006 09:15 PM
hans stoner
Oct 2, 2006 06:11 AM
da_33
Jun 12, 2006 11:26 AM
