Honda S2000 Honda S2000
Question about ECU
Old Oct 13, 2006 | 09:27 PM
chinkieboy's Avatar
Default Question about ECU
well i have a 00 S2, everything is stock on the car, but my friend said if i swap a 02-03 ECU in it, it would make a bit different, is that true? also what are some of the difference?
Old Oct 13, 2006 | 10:06 PM
silentdancer's Avatar
Default Re: Question about ECU (*****ieboy)
00-01 run richer, 02 ecu will lean it out
Old Oct 14, 2006 | 05:47 AM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy &raquo;</TD></TR><TR><TD CLASS="quote">well i have a 00 S2, everything is stock on the car, but my friend said if i swap a 02-03 ECU in it, it would make a bit different, is that true? also what are some of the difference?</TD></TR></TABLE>
Get yourself a Vafc and have it tuned. Because the 00-02's run richer than the newer models, you'll see some pretty good gains from a well tuned Vafc.
Old Oct 14, 2006 | 07:26 PM
chinkieboy's Avatar
so you guys suggest gettin 02-03 ecu or just VAFC?
Old Oct 14, 2006 | 09:07 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (*****ieboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy &raquo;</TD></TR><TR><TD CLASS="quote">so you guys suggest gettin 02-03 ecu or just VAFC?</TD></TR></TABLE>
go with a Vafc like i did since you can always make changes hen need be unlike the ECU.....
Old Oct 14, 2006 | 09:26 PM
iam7head's Avatar
dont you have to reprogram all the keys if you swap the ecu?
Old Oct 14, 2006 | 09:47 PM
ladius's Avatar
Default Re: (iam7head)
you actually have to reprogram the ecu (ecm). I had mine replaced and had to take it to the dealer because it's programmed from a dealer-only tool. they put the vin # into the ecm and all that stuff.
Old Oct 14, 2006 | 10:36 PM
chinkieboy's Avatar
my friend told me the 02-03 ECU its plug in and play.....ah i might just get a VAFC
Old Oct 15, 2006 | 02:21 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
as stated... u have to reprogram it at teh dealer because of the immobilizor
Old Oct 15, 2006 | 10:52 AM
ladius's Avatar
Default Re: (S@nt0s)
yeah, I forgot to mention that. the ecm is reprogrammed to accept the transponder in the key. I guess it makes sense that you could do it the other way and reprogram the key... but not sure. the dealer will know for sure.
Old Oct 15, 2006 | 07:49 PM
chinkieboy's Avatar
so from what you guys said..VAFC is the best way to go right?
Old Oct 16, 2006 | 10:40 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy &raquo;</TD></TR><TR><TD CLASS="quote">so from what you guys said..VAFC is the best way to go right?</TD></TR></TABLE>
It depends. Think about what you're trying to get out of the car. If you have bigger goals, get the AEM EMS.
94hondacivicvtec
11
Feb 26, 2007 03:44 PM
b18-eg6
Aug 1, 2006 05:23 AM
jdmB18CT-R
Feb 27, 2006 05:28 AM
LBDM EK97
Dec 27, 2005 03:20 PM
moekhanafer
May 13, 2005 07:48 PM
