Question about ECU
well i have a 00 S2, everything is stock on the car, but my friend said if i swap a 02-03 ECU in it, it would make a bit different, is that true? also what are some of the difference?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy »</TD></TR><TR><TD CLASS="quote">well i have a 00 S2, everything is stock on the car, but my friend said if i swap a 02-03 ECU in it, it would make a bit different, is that true? also what are some of the difference?</TD></TR></TABLE>
Get yourself a Vafc and have it tuned. Because the 00-02's run richer than the newer models, you'll see some pretty good gains from a well tuned Vafc.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy »</TD></TR><TR><TD CLASS="quote">so you guys suggest gettin 02-03 ecu or just VAFC?</TD></TR></TABLE>
go with a Vafc like i did since you can always make changes hen need be unlike the ECU.....
you actually have to reprogram the ecu (ecm). I had mine replaced and had to take it to the dealer because it's programmed from a dealer-only tool. they put the vin # into the ecm and all that stuff.
yeah, I forgot to mention that. the ecm is reprogrammed to accept the transponder in the key. I guess it makes sense that you could do it the other way and reprogram the key... but not sure. the dealer will know for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy »</TD></TR><TR><TD CLASS="quote">so from what you guys said..VAFC is the best way to go right?</TD></TR></TABLE>
It depends. Think about what you're trying to get out of the car. If you have bigger goals, get the AEM EMS.
