VAFC or modified ECU
Old May 11, 2005 | 02:54 PM
moekhanafer's Avatar
Default VAFC or modified ECU
I have a 92 gsr with a 2000 gsr motor swapped. I've got a fully modified ECU, but my question is, do I need to sell the VAFC that I earlier bought or should i use it aswell. I was thinking because the modified ECU has the v-tec adjustment and the whole works, the VAFC would be useless.... or maybe im wronge.....help!!!!!!!
Old May 11, 2005 | 03:24 PM
iH8RICERZ's Avatar
Default Re: VAFC or modified ECU (moekhanafer)
who "FULLY MODIFIED" your ecu? what program? custom map made specifically to your mods?
KEEP the VAFC and get your car tuned by a pro... simple as that
no2unenolife's Avatar
don't think it would be smart to run both.
i used to run chipped ecu and safc on my ls, not good. pick one =D
Old May 11, 2005 | 08:28 PM
Integra_drk's Avatar
if your ecu has not been professionally mapped and you use the vafc then they will interfere, sending your engine different messages, possibly endangering the vtec, then youll have problems.
Old May 11, 2005 | 10:51 PM
mtber's Avatar
A vafc isnt the best solution. A ecu mapped specifically for your setup would be an idea solution.
Chipped ecus, ecu chipping etc: https://honda-tech.com/zerothread?id=1242980
From pgmfi (Good way to describe piggybacks):
Piggy Back controllers allow stock ECUs to do things that they normally can't do, like run larger injectors or deal with boost. Remember that piggyback controllers work by altering sensor signals before they get to the ECU.
Most of the time, the primary signal being messed with is the Map Sensor. This is critically important in a Speed Density car. The Map Sensor is used by the ECU to guess how much air is going into the car, and therefore how much fuel to supply in order to match airflow. When you "lean" out a car with an AFC, you are simply decreasing the Map Sensor signal - the ECU responds to the decrease in manifold pressure by supplying less fuel. When you "richen" a car with an AFC, you are simply increasing the Map Sensor signal - the ECU responds to the increase in manifold pressure by supplying less fuel.
The change in fueling happens for a reason: if you look at a fuel table, Map Sensor values correspond with columns. When you increase or decrease the signal from the Map Sensor, you are simply making the ECU use a different column than it originally would have used. (see Understanding Maps if you need some help understanding reading Fuel and Ign tables)
But wait, isn't the Map Sensor used for determining ignition requirements too? When you "lean" out a car with a Piggy Back, you also in all likelyhood advanced timing. When you "richen" a car with a Piggy Back, you also in all likelyhood retarded timing. Look at trends horizontally (as MAP changes) in an ignition table, and you will see why this happens. This helps explain why so many boosted cars running on the "AFC hack" have issues due to excessive ignition advance.
The bottom line: Piggy Back Controllers suck because you cannot independently adjust fuel and ignition. Any changes to fueling will produce a change in ignition too, and often this is undesirable.
Old May 12, 2005 | 06:32 PM
Default Re: VAFC or modified ECU (mtber)
soo your saying I i should throw away my VAFC,, and stick with the performance ecu or what ???? lol
Old May 13, 2005 | 07:21 AM
is that what your saying???
Old May 13, 2005 | 07:48 PM
d_sac40's Avatar
throw it my way
b18-eg6
Aug 1, 2006 05:23 AM
lsvsol
May 12, 2006 07:03 PM
inzane
Nov 21, 2005 12:36 AM
Richard.
Nov 23, 2003 12:36 PM
EJK
Apr 14, 2002 12:55 PM
