clutch pedal is low
i bought a 95 civic dx the kid who had it before me said that he had bought a stage 1 clutch off ebay but whats wierd is that the clutch pedal sits very low. to press on the clutch its only like a two inches long. its a pain sometimes cuz the car tends to jump when letting go slowly.
wrong you have to get a new clutch bc that bs one is about to burn out. the reason is bc the pressure plates that comes with those kits are crap (it happened to me when i bought the car) i ended up being a hard head and my tranny when kaphooie
Put the car in 3rd gear when stopped---If you can take off in 3rd gear then your clutch is ****.
Most likely you just need to adjust the master cylinder like Dcsports said.
If you look behind the clutch pedal, there is a metal rod going into the master cylinder. By spinning the rod you can adjust the clutch pedal distance. Just play around with it untill you like were it is at.
CAVTECSol
Apr 1, 2011 09:34 AM
beanwagon
Dec 12, 2008 02:55 PM
s1ngle
13
Sep 21, 2005 12:01 PM
good job
