Not starting
Old Oct 12, 2006 | 06:49 PM
InvaderTrax's Avatar
Default Not starting
Alright, it's a '94 EX, and for the past several days it won't start. It was running fine, then we ran a compression test, and now it won't start. It turns over fine, and has fuel, but no spark. Plugs and wires are fine, as well as all fuses. I figured it was either the coil or ignitor, so I brought it to a shop and they replaced them both. Dropped it in the car, still no spark. Any suggestions?
Old Oct 12, 2006 | 06:51 PM
Miracle's Avatar
Default Re: Not starting (InvaderTrax)
It could possibly be the distributor itself, or possibly a bad ground or something else electrical....
No DTC's?
Old Oct 12, 2006 | 06:55 PM
That's next is to put this distributor on an otherwise working car (as well as test a known working distributor). No codes
Old Oct 12, 2006 | 06:56 PM
Miracle's Avatar
Default Re: (InvaderTrax)
A bad distributor should throw a code. Interesting.
I would check the engine ground to be the last thing... But maybe I am wrong.
Old Oct 12, 2006 | 07:01 PM
hondamark35's Avatar
have you tested power to the distributor/ignitor?
Old Oct 12, 2006 | 07:08 PM
B18bEG6ick's Avatar
i had the same problem before on my car, but i knew i had a bad coil. i just replaced the whole distributor from ebay (cheaper than a coil almost). when i put it in and hooked up everything, it didn't want to start for a bit. i think i washed out the rings and wasn't creating compression, cause i tried to start it a lot of times. so i placed a oil and then i got compression and then it started. just get a new distributor and take it from there.
Old Oct 13, 2006 | 07:49 PM
Alright, we replaced the entire distributor with a tested one, and still doesn't work. Which wires should I check for voltages and what should they read?
Old Oct 15, 2006 | 05:59 PM
B18bEG6ick's Avatar
http://jdmlyfestyle.com/how_to...m.htm
this what i used to check my coil.
jdmkidUK
Nov 30, 2011 05:49 PM
1badcrx
May 9, 2009 12:58 AM
ILuvMyJdmDc4
Nov 27, 2007 05:17 AM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
KaRiZMa
Nov 7, 2004 03:30 AM
