does check engine light mest up my performance?
Old Oct 12, 2006 | 02:32 PM
nek9's Avatar
Default does check engine light mest up my performance?
like the title sees. does check engine light mest up my performance?
Old Oct 12, 2006 | 02:39 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: does check engine light mest up my performance? (nek9)
sure, if the gasket is blown or your o2 sensors aren't working.
Very vague question, The check engine light can range from sensors to you not having your gas cap tightened enough.
Old Oct 12, 2006 | 02:49 PM
nek9's Avatar
Default Re: does check engine light mest up my performance? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">sure, if the gasket is blown or your o2 sensors aren't working.
Very vague question, The check engine light can range from sensors to you not having your gas cap tightened enough.</TD></TR></TABLE>
i guess i didnt make the qestion specific. I was actually asking about the o2 sensor?
Old Oct 12, 2006 | 02:52 PM
Ek Forever y0!
Then yes.
You should have asked about the o2 sensor. Your check engine light could be X amount of things.
Your o2 sensor will make a difference because it will alter your air/fuel ratio because your ecu isnt getting a correct reading.
Old Oct 12, 2006 | 02:59 PM
nek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Then yes.
Your o2 sensor will make a difference because it will alter your air/fuel ratio because your ecu isnt getting a correct reading.</TD></TR></TABLE>
tnx that really help
vxtirent08
Mar 22, 2008 10:51 PM
civicsaremean
Jun 24, 2007 08:27 AM
JinDIESEL
Sep 17, 2004 06:33 AM
Loveless
Jun 8, 2003 10:02 AM
