which is better? b16 head or gsr head?
Old Oct 12, 2006 | 01:08 PM
b20_driven's Avatar
Default which is better? b16 head or gsr head?
i have a b16 longblock and a type r block and a gsr head lying around. and the thing is that i don't know if i should take the head off the b16 and slap it onto the type r or should i slap the gsr head onto the type r? the gsr has been ported and polished and plus its chambers has been opened and all it needs is a valve train. or should i spend the extra money on the b16 head and slap it onto the type r block??
Old Oct 12, 2006 | 01:37 PM
si0385.'s Avatar
Default Re: which is better? b16 head or gsr head? (b20_driven)
i would put the gsr head on the type r block.. it has a smaller combustion chamber so it will yeild high compression than the b16
Old Oct 12, 2006 | 02:27 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: which is better? b16 head or gsr head? (si0385.)
b16 head has the same blueprints as the type-r head. So it will yield higher compression. Poorman's type-r = gsr block and b16 head with type r or modded internals.
Old Oct 12, 2006 | 02:46 PM
-Trinitron-'s Avatar
GSR HEAD on the ITR block
It raises the compression from 10.6 to 10.8 with 1797 cc.
vs. the 10.6 that would yield from the ITR/B16 head
Old Oct 12, 2006 | 02:53 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: which is better? b16 head or gsr head? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">b16 head has the same blueprints as the type-r head. So it will yield higher compression.</TD></TR></TABLE>
Wrong. Pentroof combustion chambers on the P72 casting yield slightly higher compression then then domed ones found in the PR3 castings.
Old Oct 12, 2006 | 02:58 PM
Ek Forever y0!
Default Re: which is better? b16 head or gsr head? (Mr Hammond)
statement retracted.
Old Oct 13, 2006 | 05:11 AM
b20_driven's Avatar
but i had the chambers in the gsr head opened for better flow. wouldn't that lower the compression a bit? i really want the compression to be as high as can be with the stock oem block.
i thought usdm type r cpr is 11:1?
Old Oct 13, 2006 | 01:53 PM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_driven &raquo;</TD></TR><TR><TD CLASS="quote">but i had the chambers in the gsr head opened for better flow. wouldn't that lower the compression a bit? i really want the compression to be as high as can be with the stock oem block.
i thought usdm type r cpr is 11:1?</TD></TR></TABLE>
if you had it ported they just ported the intake runners not the combustion chambers it will not effect compression
Old Oct 14, 2006 | 04:34 AM
b20_driven's Avatar
intake runners definitely are ported and mildly polished, but combustion chambers definitely are opened too.
Old Oct 14, 2006 | 04:38 AM
Sleepy_Red_hatch's Avatar
usdm R = 10.80:1
jdm R = 11.32:1
lilskud13
Apr 2, 2009 12:38 PM
Drew17th
Oct 11, 2006 10:18 AM
rock~1
29
Jun 21, 2006 07:53 AM
FROSTDC2
Oct 27, 2005 09:40 PM
maxheat
24
Feb 26, 2005 12:36 PM
