DA lsvtec almost done need advice!!!
Old Oct 11, 2006 | 08:39 PM
truteg801's Avatar
Default DA lsvtec almost done need advice!!!
im just about finished with my ls vtec on a 91integra obd0 and almost ready for the start up. heres the set up.
p72 head
rebuild b18a1 block
p30 pistons
pr3 chipped ecu
stock gsr manifold
b16a camshafts
the question im trying to ask is
i dont have a knock sensor or o2 will i be safe just disabling them?
what should i do for the fuel and ignition map or base map to run for the high comp?
Old Oct 12, 2006 | 08:45 PM
truteg801's Avatar
Default Re: DA lsvtec almost done need advice!!! (truteg801)
bump!!!
Old Oct 15, 2006 | 08:12 AM
SYNSEI's Avatar
Who chipped your ECU? A lot of times you wont need a knock sensor after the chip (like phearable).
Old Oct 16, 2006 | 10:27 AM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truteg801 &raquo;</TD></TR><TR><TD CLASS="quote">im just about finished with my ls vtec on a 91integra obd0 and almost ready for the start up. heres the set up.
p72 head
rebuild b18a1 block
p30 pistons
pr3 chipped ecu
stock gsr manifold
b16a camshafts
what should i do for the fuel and ignition map or base map to run for the high comp?</TD></TR></TABLE>
use a timing gun to make sure your base timing is 16 degrees first then tune on a dyno from there. As for air/fuel...tune for 14.5 at idle, then progress to 13.0 at WOT (these are general but safe guidelines). You can't tune without a wideband.
Vash121991
Apr 12, 2012 02:51 AM
Fall_out_boy_99
Aug 28, 2010 10:09 AM
0o_coupe
May 28, 2007 06:58 PM
untitled
Aug 9, 2003 08:07 AM
DOHCRX
18
Feb 19, 2003 01:51 PM
