93 Prelude fan problems. Help me out please!
Old Oct 11, 2006 | 06:00 PM
Entaka's Avatar
Default 93 Prelude fan problems. Help me out please!
My fans dont seem to come on at all. I dont drive the car yet because my swap is STILL in progress. needs new brakes and other odds and ends before i can drive it BUT before i can do all that I have to fix this problem. The fans do not turn on at all when i leave it running in the drive way. The temp gets up to about half way then i turn it off. I tested the fans by putting them directly on a 12v source and they work fine. I got a new relay switch thinking that would fix the problem but it didnt. before i did all this, i noticed mouse, or just heat rot over the yeards, did away with a few wires on the passenger side ground plate so i redid those grounds. I guess the question would be where do the fan wires go before they go back to the relay? The only other thing that would make sense to me is that the wires are botched up somewhere along that line. Ive also read something about the fan timing computer being a problem but havent looked into that yet because my fans dont come on AT ALL and the people with the fan computer problem were having them come on when the engine was shut down and not when running.
If anyone has ANY idea as to WTF could be wrong...it is much appreciated. Everytime i think the car is done something else comes up
Old Oct 15, 2006 | 12:30 AM
Entaka's Avatar
Default Re: 93 Prelude fan problems. Help me out please! (Entaka)
::sigh:: late night bump
Old Oct 15, 2006 | 01:50 AM
Cottonwoodz's Avatar
normal temp is half-way........
Old Oct 15, 2006 | 05:24 AM
SnlpeR's Avatar
my car takes like 20 minutes or more for the fans to finally turn on
Old Oct 15, 2006 | 06:53 AM
Duane_in_Japan's Avatar
Default Re: (SnlpeR)
You need a wire diagram and hot wire things from the fan, working back through the relays, thermo switches, timer, AC power switch, AC thermo controller. Turning on the AC should power up both fans.
Old Oct 15, 2006 | 07:47 AM
oranginal's Avatar
check your thermostat ground and
also try to jump the thermo-switch.
it's the green connector that goes into the thermostat housing.
if the fans turn on then it should be your thermo-switch (sesnsor).
Old Oct 15, 2006 | 09:06 AM
'95 BA8's Avatar
Default Re: (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">normal temp is half-way........ </TD></TR></TABLE>Strange....mine is always at a quarter..
clean_sol93
Dec 11, 2011 08:39 AM
obuhmyuh
Nov 17, 2007 08:51 PM
hassan21
Aug 30, 2007 12:37 PM
turbo gsr
Jul 9, 2006 01:14 PM
riceball777
May 9, 2003 09:00 AM
