OVERHEATING PROBLEM!!
Start off i have a blown head gasket but the car is still driving. My radiator fan doesn't kick on at all when driving but when i turn it off and turn back on without running the engine the fan kciks on for 10 secs if am lucky. The car only overheats when i go long distances on the highway. Today i put in a new thermostat to see if that will help the fan. I guess i insall it right cuz i foloow all the instructions but when i drive my temperature guage keep going over half way and then goes down and back up. I dont know what to do. I already have a head gasket i just want to fix the fan problem before i put it in and the smam e thing happens again
Check this thread out and see if it helps. Before the switch, I would definitetly replace the head gasket and see if that fixes it.
-Shane
-Shane
It could be a few things. Try to change out your thermoswitch, it's not much of a switch but you know what i mean. The switch is the part thats gonna kick your fan on. Is the fan wired up from factory or has it been hacked up? The head gasket is helping the problem definately, I myself have a blown headgasket but my car doesnt over heat that fast. So thats not completely the problem. The only other thought i could help you with is that maybe it's just that there are air bibbles in you coolent system. That would make your temp. rise and fall like you were saying. Good luck, i hope i helped you out some!
thanx it should be copnnected factory no one i know hack into it but if it does have air bubbles is there a way to get rid of it and it their a way to install a switch manual so when you need it you can put it on
listen man! are u doing the repairs yourself? and is that why your hesistant?
Are you losing coolant?or water which ever you use. Are you driving alot? your fan helps to cool but its not the main reason why it is overheating. Is it overheating extremly? did changing the thermostat help at all? when is the last time you had a coolant flush?
yea i doin some repairs by myself and wat r u talkin about being hesistant yes im losing little coolant and i do drive i hve to i live in florida it only overfheat extremly when im on the highway and for more than 40 minutes when i change the thermostat the old one the spring broke off because of it overheating i guess and when i replace it my temperature readin is goin up and down in the middle section and the last time i flush was today when i change and before like 2 months ago
Malt-liquor
Sep 25, 2017 05:21 PM
Marauder
May 25, 2006 01:09 PM
