swapping a d16y8 into a cx
Old Oct 11, 2006 | 11:01 AM
civicb16eg's Avatar
Default swapping a d16y8 into a cx
well im taking out my b16 swap next week and putting in a d16y8 obd2.....juss wondering what i would need to convert the swap into an obd1....any help would be appreciated..
Old Oct 11, 2006 | 11:05 AM
TurboTagTeam's Avatar
Default Re: swapping a d16y8 into a cx (civicb16eg)
What....Why??? Are you selling it or something????
Just of the top of my head...Your gonna need an OBD1 dizzy, OBD2 to OBD1 conversion harness
Old Oct 11, 2006 | 12:04 PM
HondaPartsHero's Avatar
Technical Hero
I am assuming you have a EG OBD1 civic according to your screen name correct? You will need to swap the Y8 dizzy plugs over to the OBD1 plug if they're different and if you are using the Y8 injectors you will need to swap out the plugs for the OBD2's to use its injectors or just use some injectors from an OBD1 vehicle. Also the alternator plug is different so you will need an OBD1 alternator or I have seen some people swap over the plug in portion from an OBD1 alternator to an OBD2 alternator. You will also need to relocate the Intake Air Temperature sensor to the intake arm because the Y8 manifold doesn't have a spot for it. I guess you could use the P28 ECU for the swap to run it.
Old Oct 11, 2006 | 12:08 PM
big-cat's Avatar
repin the d-series. u should go t-bo.
Old Oct 11, 2006 | 05:44 PM
civicb16eg's Avatar
Default Re: (big-cat)
thanks for the help guys...yea im swapping out the b16 and putting in the y8 to sell the car
Old Oct 11, 2006 | 05:46 PM
civicb16eg's Avatar
Default Re: (civicb16eg)
is there anything else i need?....
Old Oct 11, 2006 | 09:42 PM
civicb16eg's Avatar
so all i need is an OBD 1 dizzy, OBD 1 alternator, OBD 1 injectors, anything else?
Old Oct 12, 2006 | 09:48 PM
civicb16eg's Avatar
anyone?
DC206R
Mar 6, 2009 09:56 PM
civicracer94
Sep 12, 2007 12:16 AM
fbmbmx
Oct 16, 2006 05:12 PM
haroldthefly91crx
Sep 13, 2006 04:35 PM
gearhead313
Mar 2, 2003 01:44 PM
