I have tein springs, could i still get the coil overs, if i want ,
Tein coilovers use a standard sized spring which is NOT very similar to the OEM, aside from the fact that it has coils.
the tein is like a 2.25 or 2.5" springx 6-8" long(not sure on tein)
the spring you have is stock sized, and is designed to fit an oem damper, and is MUCH longer then 6-8"
No, it wont work.
No, it wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt »</TD></TR><TR><TD CLASS="quote">
No, it wont work.</TD></TR></TABLE>
I dont think you understand the definition of coilovers. All they are is a threaded sleeve which allow the spring height to be changed, without changing preload. You have a different spring rate then stock, but the spring is the same style as oem. coilovers have a spring with a flat top and bottom, and a smaller diameter spring then OEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt »</TD></TR><TR><TD CLASS="quote">No, it wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00****chico »</TD></TR><TR><TD CLASS="quote">BECAUSE I DONT KNOW IF THE CAR IS ALREADY HAVE BEED LOWERED DOWN, COULD I JUST TAKE THEM OFF , AND PUT THEM ITH THE TEIN COIL OVERS, TO MAKE IT BETTER......I JUST WANT TO GET THE ONES THAT U CAN MANAGE THE HEIGHT OF THE RIDE, JUST ASKING ANYONE KNOW SOMETHING.......<></TD></TR></TABLE>
This has got to be the only thread that you didn't delete your original post.
young noob #2
Suspension & Brakes
10
Jul 29, 2008 11:57 AM
justseeingifitistaken
Apr 2, 2008 06:14 AM
