spring rates for TEIN SS
Old Feb 25, 2003 | 07:38 AM
Paluce's Avatar
Default spring rates for TEIN SS
I have a set of TEIN HA's for my 01 lude, but the 675lb F and 450lb R spring rates are a little too much for a daily driver on Michigan roads. (I wish I worked some place else!)
anyone know the spring rates for the TEIN SS's?
Also, are the dampers the same for the SS and HA's? or different?
Thanks,
Daniele DeFranceschi
[Modified by Paluce, 5:51 PM 2/25/2003]
Old Feb 25, 2003 | 08:23 AM
Variance's Avatar
Default Re: spring rates for TEIN SS (Paluce)
http://www.tein.com has all your answers.
The spring rates are 8F 4R kg/mm which translate to 448F 224R lb/in. I've been told from a Tein distributor that the shocks are valved less agressively than the HA. So the SS is definitely more for street driven daily drivers.
[Modified by Variance, 9:24 AM 2/25/2003]
Old Feb 25, 2003 | 08:53 AM
Paluce's Avatar
Default Re: spring rates for TEIN SS (Variance)
That's a little softer in the rear than I wanted... I was hoping for something closer to 300. I guess I'm too picky!
what to do, what to do????
Old Feb 25, 2003 | 01:07 PM
SleekBlkPrelude's Avatar
holy ****! haha... those spring rates were off the wall... that is way tooooooo stiff... i have ground control coilovers on my ride and i have 400 front and 375 rear... just a lil bit stiffer than what gc usually sends which is 375 front 350 rear...
but up to 450 front and 425 rear is perfectly fine for street roads...
Old Feb 26, 2003 | 08:30 AM
Variance's Avatar
Default Re: spring rates for TEIN SS (SleekBlkPrelude)
Oh I forgot. You can order special spring rates from TEIN. So maybe you can get your 300lb springs.
http://www.turboevolution.com, and email him what you need. Good guy Great service! From what I hear it is $50/spring.
eluam
Oct 20, 2008 08:11 AM
JDM Factor
Aug 6, 2006 04:12 PM
1SIKEG6
Suspension & Brakes
Feb 19, 2006 08:40 AM
donz
Jun 27, 2004 11:45 AM
