B16a and GSR.. What parts are interchangable?
Old Oct 10, 2006 | 12:46 PM
SimplyTron's Avatar
Default B16a and GSR.. What parts are interchangable?
I have a OBD0 b16a in my CRX right now and I plan on doing a OBD1 GSR swap. I have a Y1 tranny with LSD that I want to put on the GSR. Im pretty sure that will work since theyre both B Series but what about the flywheel and clutch/pressure plate? The GSR I am getting will not have a flywheel on it. Also Im pretty sure but I just want to confirm this, intake manifolds are not interchangable but the header is right?
Old Oct 14, 2006 | 10:13 PM
95GSRBOI's Avatar
Default Re: B16a and GSR.. What parts are interchangable? (SimplyTron)
no
Old Oct 14, 2006 | 10:28 PM
mmuller's Avatar
Mad Scientist
tranny will fit; the clutch disk is what differs between the 2 spline sizes.
Old Oct 14, 2006 | 10:35 PM
Damon Reeves's Avatar
For the most part...you should look on building a "poor man's type R"=B18c1 bottom end with the b16 head....get the head port and polished....add ctr pistons and camshafts...you should be a lot quicker than your stock gsr....as for manifolds---they do not have the same bolt patterns...but the Type R intake manifold is same as the b16's and they also have short runners as well....tranny is also interchangeable...good luck keep us updated
Old Oct 15, 2006 | 11:12 AM
inspyral's Avatar
If it's a B16A- specific header, it might not clear the B18C block, since the B16A deck height is shorter.
Old Oct 15, 2006 | 08:54 PM
95GSRBOI's Avatar
Default Re: (inspyral)
b16a will not fit on b18c1 block. Tried it with my friends before I thought about grapping the dcs-ports off him, but did not fit due to length.
Old Oct 16, 2006 | 03:08 PM
Default Re: (95GSRBOI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRBOI &raquo;</TD></TR><TR><TD CLASS="quote">b16a will not fit on b18c1 block. Tried it with my friends before I thought about grapping the dcs-ports off him, but did not fit due to length.</TD></TR></TABLE>
You've never heard of the poor man's type r? The b18c is basically the b18c1 bottom end with a port and polished b16 head...
Old Oct 16, 2006 | 03:25 PM
mmuller's Avatar
Mad Scientist
Default Re: (My DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My DC2 &raquo;</TD></TR><TR><TD CLASS="quote">You've never heard of the poor man's type r? The b18c is basically the b18c1 bottom end with a port and polished b16 head...</TD></TR></TABLE>
he means header lenght; since as said above pr3 block has a shorter deck
Old Oct 16, 2006 | 03:28 PM
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
he means header lenght; since as said above pr3 block has a shorter deck</TD></TR></TABLE>
oh yeah of course
b20beast83
Sep 12, 2008 05:55 PM
AP1_man
Feb 24, 2007 11:58 PM
Vantage
Sep 8, 2005 04:43 AM
JDMej1Civic
Apr 22, 2005 09:04 PM
c0wvin
May 28, 2003 03:34 PM
