Where to find Pre-built motors...
Old May 2, 2002 | 10:02 PM
Jay94GSR's Avatar
Default Where to find Pre-built motors...
Hey folks, I was thinking about going turbo with my 94 GSR but it has 106,000 miles on it, and its probably not the best idea to do without rebuilding it first, so I'm just gonna get rid of it and sell it to someone. I recall getting some catalogs a while back that had pre-built motors in it, with the turbo, cams, turbo mani, injectors, etc already put together. Unfortunatly I threw them away, not thinking I wanted to get one. I was curious if any of you know of any websites or dealers that would carry these motors. Any help would be appreciated.
-Jay
[Modified by Jay94GSR, 7:04 AM 5/3/2002]
Old May 2, 2002 | 10:07 PM
Malice's Avatar
New User
Default Re: Where to find Pre-built motors... (Jay94GSR)
i know importbuilders.com has some
xJ.SLOTHx's Avatar
http://www.importbuilders.com
http://www.exospeed.com
theres a couple...hope i helped
Old May 2, 2002 | 10:19 PM
intekragsr's Avatar
Default Re: Where to find Pre-built motors... (ian)
importbuilders.com
threatcon13's Avatar
New User
importbuilders 2.0 liter turbo block.
Old May 2, 2002 | 10:21 PM
Jay94GSR's Avatar
Thanks for the info guys, but it seems the best motor importbuilder has is a t03/t4 setup with only 225 whp going for about 3500, I'm looking for more along the lines of 300+ whp.
[Modified by Jay94GSR, 7:24 AM 5/3/2002]
Old May 2, 2002 | 10:23 PM
intekragsr's Avatar
if you get the import builders 2.0 liter GE sleeved block, drag 3 kit, and hondata, you will be able to push 350+ with propor fueling and tuning.
Old May 2, 2002 | 10:26 PM
Jay94GSR's Avatar
Default Re: Where to find Pre-built motors... (intekragsr)
intek,
I was looking into the drag gen 3 kit before and thats exactly what I wanted, but the kit costs 2200+ on groupbuycenter. How much do you think everything will go for If I go with the 2 liter hydro LS importbuilder has with the t03/4 turbo, then take that out and put in the drag gen 3 kit? The golden eagle sleeves are already on the motor they have and so is the hondata ecu.
BTW - Are you using your stock motor, and if so how many miles do you have? Im still considering if I should keep the motor I have now or not.
[Modified by Jay94GSR, 7:30 AM 5/3/2002]
Old May 2, 2002 | 10:29 PM
intekragsr's Avatar
i dont know how much it will cost. For me, I would guess 8000-9000 will cover all that plus some tuning with a hondata. Cheaper if you install everything yourself.
Old May 2, 2002 | 10:32 PM
Jay94GSR's Avatar
Well I may be able to get off cheap on the work and install, I have a friend who is a mechanic at a saturn dealer, he works on nissans to, he may be able to work on my car for a lot cheaper.
Old May 2, 2002 | 11:16 PM
SIK IN DA HED's Avatar
New User
use your stock block and boost it. alot of us have and still do.
9TechNine9
Aug 2, 2016 11:33 AM
k24coupe
Aug 19, 2012 10:48 AM
odishaw
Aug 26, 2007 11:33 PM
-KangaRod-
Feb 17, 2004 03:36 PM
JunIntegra
Nov 15, 2003 06:04 PM
