car cranks more before starting
Old Oct 7, 2006 | 12:22 AM
davidluko's Avatar
Default car cranks more before starting
Don't know if I should be worried or not, but lately I noticed that it takes probably about 3 cranks to start my car (B18b1) vs. just 1 crank before. Today when I started it cold after standing overnight the idle rpm was going up and down for a second and the car sounded like it wanted to die but then it starting idling normally. I turned it off, started it a little later, and it did it again a little but not as bad, and none at all any other time after that. Should I be worried?
Old Oct 8, 2006 | 04:53 PM
00s2KkId's Avatar
extended crank time could mean ur fuel pump is gettin weak...and sounds to me like u should clean out ur iac
Old Oct 8, 2006 | 04:58 PM
phanatic's Avatar
Default Re: (00s2KkId)
if you dont change your oil in a long time cant this happen too?
Old Oct 8, 2006 | 05:20 PM
gsr dood's Avatar
Default Re: (phanatic)
it def something with the fuel. either ur pump is gettin weak or there is somehow air inside the line before u start it.
Old Oct 8, 2006 | 10:22 PM
davidluko's Avatar
Doubt there would be air, wouldn't there need to be a leak somewhere along the path of fuel for air to get in? Because I haven't seen/smelled any leaks. And my oil is new too, less than 1000 miles. Would an old battery do that? That's what I was leaning towards. Also, if it is the fuel pump going bad, how would I be able to test that? Would there be any signs I could see with a volt meter or would the problem be non-electric-related? If it is the problem, I have another stock pump laying around somewhere.
byrne_06
Feb 25, 2013 05:37 AM
Auto96accord
Oct 16, 2006 04:00 PM
OLDskool91Si
Oct 14, 2006 11:11 AM
del_parker
Jan 12, 2004 02:03 PM
-BlueGSR-
Feb 11, 2003 09:53 AM
