back for more "no start"great untill this afternoon when help
You guys were such a great help to me this summer with my daughters 92 civic, which had a bad main relay connection. Well now I need your help again.
The car has been running great untill this evening when it would turn over fine but refuse to start. It's been quite cool and I can smell gas but it will not fire. My daughter is waiting for that hero moment when I fix it . Hope you can help.
Thanks,
Dave
Thanks,
Dave
My daughters Civic did that all of a sudden last month. I checked for spark and had it so I ended up taking the rotor out of the dizzy and cleaning it with a wire brush as well as inside the dizzy cap and tried it and it started. So afterwards I purchased a new cap and rotor and all is well.
I hope this helps & good luck.
Tzer
Tzer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tzer »</TD></TR><TR><TD CLASS="quote">My daughters Civic did that all of a sudden last month. I checked for spark and had it so I ended up taking the rotor out of the dizzy and cleaning it with a wire brush as well as inside the dizzy cap and tried it and it started. So afterwards I purchased a new cap and rotor and all is well.
Tzer</TD></TR></TABLE>
What he said.
when a motor turns over, but doesn't fire, you either are not getting fuel, or you are not getting spark.
Just check everything out, make sure you are getting both first and foremost.
What he said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave P »</TD></TR><TR><TD CLASS="quote">I should also have said that this was the first frosty night we've had this season so maybe a moisture problem ?</TD></TR></TABLE>
It is possible, but not first on the list.
If it is though, there is a seal problem.
Just because your fuel pump is working, doesn't always mean you are getting fuel to your cylinders.
You need to check and see if you are getting fuel first of all. Because without that, obviously there will no starting the engine.
YOu are already getting spark, so leave that alone.
If you are getting spark and the coil was just replaced then I would check fuel pressure and compression of the motor. If both of those check out ok could it possibly be bad gas? or the timing could have gotten knocked off somehow. Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave P »</TD></TR><TR><TD CLASS="quote">Maybe it's that ralay again?</TD></TR></TABLE>
Negative. If it was, the car would not even crank, and you definately would not get spark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">
Negative. If it was, the car would not even crank, and you definately would not get spark. </TD></TR></TABLE>
this is incorrect you can have a bad relay and the car will just keep cranking and cranking..or maybe you ment turn over as in start??
but since you replaced it already it will not be the problem. since you have fuel, and since you have a new coil.
the onlyother part you need to check is the distributor "ignitor" if you open up the distributor cap you will see the coil to the right, now go to the left side and you will see 3-4 wires that connect into a square thing.. that is your ignitor..
ignitors go bad just as weird as do relays...
you can use any 92-01 civic or integra ignitor they are all the same...
i told you what the problem was last time... lets see if im correct this time around.. the ignitor , let us know.
as far as fuel pressure a car will still turn on with low fuel pressure and compress, it just will not run smoothly, but it will start the car up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave P »</TD></TR><TR><TD CLASS="quote">The ignitor makes alot of sense. I'll replace it and let you know how I make out.
Great to have your help.</TD></TR></TABLE>
yea see if you can get one from a friends car if possible, i cant remember how much a new costs but i think its pretty expensive brand new for such a small part. also try cleaning the contacts aswell.
if you have spark then neither your coil or the ignitor is the culprit. first pull the plug wires out and check the spark plugs for any oil on top where the wire plugs onto. reason being, if you have spark but its not getting to the plug, due to slow oil buildup in the chamber =no start i would check for fuel at the injectors just to be sure.. could be a clogged fuel filter..just rule out the little things before we look at jumped timing.. good luck to getting your daughters car running
one more thing,,check all fuses just to be sure, these cars have a problem with the harness rubbing on the back intake manifold bracket and shorting wires out..
I hope you guys don't give up on me cause I'm at the end of the line with this thing: Fuel pump ok, fuel filter ok, I have spark to the plugs, I have new coil and new main relay. It went from running great to not starting, overnight??
Thanks for you help
dave
Thanks for you help
dave
How did you check to see if you have spark.
Do you have spark on all four cylinders?
Do you have fuel to all four cylinders?
are you sure that you put the plug wires back in the right order?
Tell us exactly what you have done
platinum_rich
15
Feb 25, 2012 08:16 PM
VvPeachyvV
Jun 15, 2006 09:59 PM
tarheeler
May 18, 2005 06:19 PM
