boosting my teg at the end of the month
Old Oct 6, 2006 | 08:19 AM
InTeGrA_bLazEd's Avatar
Default boosting my teg at the end of the month
i have a 95 LS with 139K on it. i plan to purchase a drag gen 3 turbo kit. the only reason why im getting a kit is because this is my first. i wanna learn more about it without too much complications on my first try. i didt a compression test and the #s were 175, 170, 160, 180. i know thats a big variation but is it safe to boost. i was told that the kit would be perfect for what i wanna do. im not looking for a crazy amount of power. just a noticeable difference in performance. this is a daily driver. i wanna get between 250-300 whp. do you guys recommend upgrading any parts or will the kit do just fine?
Old Oct 6, 2006 | 12:24 PM
VTECth1s's Avatar
Default Re: boosting my teg at the end of the month (InTeGrA_bLazEd)
The kit will do you justice if you want to stay stock. just have a reliable and experienced tuner to make your car run domestics off the road lol. But upgrades will just add more whp to the motor. GL!
Old Oct 6, 2006 | 04:24 PM
red01teg's Avatar
Default Re: boosting my teg at the end of the month (DC2vtak)
The parts included in most turbo kits will cover u well. If u daily push bw 4-6psi you should be fine. Good luck.
Old Oct 6, 2006 | 06:24 PM
VTECth1s's Avatar
Default Re: boosting my teg at the end of the month (red01teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red01teg &raquo;</TD></TR><TR><TD CLASS="quote">The parts included in most turbo kits will cover u well. If u daily push bw 4-6psi you should be fine. Good luck.</TD></TR></TABLE>
he'll be fine around 6-11psi..on a good tune, but also keep in mind the size and type of turbo he is using. You cant really determine which psi to stay on depending unless he knows what turbo he is using. 4-6 psi on a mitsubishi turbo is different from 4-6 psi on a T66 or 60-1 turbo, theres a big power difference there...but most likely start out with a small turbo and you'll be fine running anywhere from 6-11 psi daily, with a good tune of course.
Old Oct 7, 2006 | 01:44 AM
juda7's Avatar
Since your in L.A. Consider Jerry Built getting you setup. He's also a good tuner.
Crazy Drag Racer.....though
Jerry Built
Old Oct 7, 2006 | 02:24 AM
no2unenolife's Avatar
you should definately get some headstuds and supertech valves.
shameless plug, check my sig
Old Oct 7, 2006 | 08:24 AM
4DRDB8GSR's Avatar
Default Re: (no2unenolife)
Use <U>DO-IT-DYNO</U> In Signal Hill, CA (Near Long Beach)
Carlos Is One Of The Best Turbo Honda Tuners On The West Coast!
BUBBA BUILT
SHOP # (562) 424-6162
Old Oct 8, 2006 | 10:44 AM
what do you guys think of my compression #s
Old Oct 9, 2006 | 03:05 PM
Zion-I's Avatar
Default Re: (InTeGrA_bLazEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRDB8GSR &raquo;</TD></TR><TR><TD CLASS="quote">Use <U>DO-IT-DYNO</U> In Signal Hill, CA (Near Long Beach)
BUBBA BUILT
X2
Old Oct 9, 2006 | 11:18 PM
01geeser's Avatar
New User
Default Re: (Justa_Old_DC2)
do yourself a big favor and ditch the fmu/inline pump setup. get some bigger injectors and any one of the great standalones out there(uberdata, crome, hondata, neptune, etc.) along with a good tune. anyone of those standalones should be reasonably affordable. that should be the first thing you wanna get. a good tune will greatly enhance your motor's longevity, power, gas mileage, and drivability.
Old Oct 12, 2006 | 08:09 AM
Default Re: (01geeser)
ok, i found a kit and injectors that i might pick up
the kit has been used for about 3500 miles but the seller says its in great condition
its a drag 3 kit that includes:
Drag turbo exhaust manifold
Turbonetics POLISHED T4/T3 TO4E High flow turbocharger assembly
Tial 35mm wastegate
Drag High Flow front mount intercooler w/ polished cast aluminum end tanks
HKS Super Sequential blow-off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Intake air filter assembly
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
and msd 550cc saturated injectors
what do you guys think? which EMS do you think would be good for this?
Old Oct 12, 2006 | 06:33 PM
01geeser's Avatar
New User
depends on your budget....uberdata is free and crome is also free if you know how to tune. or you can hit up someone who knows how to tune crome pro or neptune and have them tune it for you.
are you planning on tuning yourself or not? that would determine which ems youd wanna get.
Old Oct 12, 2006 | 08:50 PM
i have no clue how to tune.......so what should i go with?
Old Oct 13, 2006 | 12:44 AM
teknoracing's Avatar
One thing some people dont really consider is this. Location of the dealer where you are getting tuned. ITs good to live near them incase you have issues with your ECU.
Old Oct 13, 2006 | 06:39 AM
tweekerz's Avatar
If you want to go cheap get yourself a chipped p28, get a program basemap of your choice burned to the chip. Drive your car to your tuner and get it tuned.
Old Oct 13, 2006 | 10:17 AM
01geeser's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA_bLazEd &raquo;</TD></TR><TR><TD CLASS="quote">i have no clue how to tune.......so what should i go with?</TD></TR></TABLE>
id find a dealer who tunes either crome pro or neptune.
jdm95
Nov 29, 2009 03:14 PM
Rican83
Aug 28, 2008 04:23 PM
adidasklip
Sep 9, 2006 03:58 PM
s2kkid
Dec 26, 2004 06:52 PM
projectTeG
Oct 28, 2003 02:11 PM
