H23 vtec build
i an picking up an h23 bottom end this week. my h22 bottom end is warped and smokes.
i plan on putting the h22 oil/ water pump on. h22 head on the h23, the h22 oil squirters will be put in. i am keeping the h23 pistons in incase i plan to boost soon.
i was wondering what i should rev this motor to. since it has the oil squirters in it can it be safe to rev it to what the h22 goes to. (7800rpm)
i only plan to rev to 7 i think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8_HFX »</TD></TR><TR><TD CLASS="quote">i was wondering what i should rev this motor to. since it has the oil squirters in it can it be safe to rev it to what the h22 goes to. (7800rpm)
i only plan to rev to 7 i think</TD></TR></TABLE>
oil squirters do not effect the engine geometry...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">h22/h23 same sleeves</TD></TR></TABLE>
correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8_HFX »</TD></TR><TR><TD CLASS="quote">im pretty sure that the h22's use a different material for the sleeves. i know they are the same bore if thats what u mean</TD></TR></TABLE>
same bore, same sleeve material
correct
SAME FMR (AS IM TOLD)
same dech height.
same crank bearings(1992-98)50mm
same sh%t
in you use h23 block because h22 is "warped" then your ok.
but its all the same
same dech height.
same sh%t
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull »</TD></TR><TR><TD CLASS="quote">
All H are FRM sleeves... Fs are Iron....</TD></TR></TABLE>
i have a 97 a4 and it has 50mm mains. is 98+ that have 55(wish i had one)
no ...
i hope you dont plan on using forged pistons(mahle
danm two poeple got here first.(danm N.Y. time.. moderaters please reminber)
no ...
)danm two poeple got here first.(danm N.Y. time.. moderaters please reminber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8_HFX »</TD></TR><TR><TD CLASS="quote">i plan to use the h23 block. for the stronger sleeves. my h22 block is warped. so ill use the crank and rods. but pistons is the question?</TD></TR></TABLE>
use or usdm pistons for boost
jdm h22 pistons type s for high comp.
thats really cool. h_t need more members like you.
i also won a bid for h22a crower cams..... i will pass on the offer . pm me for detaials.
i dont want troble with the forum moderators so please use the pm...
no ...
i hope you dont plan on using forged pistons(mahle )
danm two poeple got here first.(danm N.Y. time.. moderaters please reminber) </TD></TR></TABLE>
no ...
racerguy
Jul 25, 2016 07:00 PM
