Tranny Issue
So I did my auto to manual swap and everything ran fine for like a block. Then something went wrong because the car wasnt going anywhere. The motor was on, and the tranny went into gear but the car doesnt move. What can the problem be? Any help greatly appreciated.
was the car in gear when she stoped pulling or were you stoped/parked? Do you have clutch pedal pressure? Are you sure you put the little bitch pin into your shifter linkage? Did you re-use an old set of cv axles and possible break one? If none of these work it could be in the tranny. Possible internal damage or maybe you just didn't intall the clutch/pp/throw out bearing properly.
Also make sure that your axles are still in the tranny. A friend of mine had the same problem. His axle popped out of the tranny, so we had to bend the clip out a little and now it's fine.
mgags7
Nov 18, 2005 08:54 PM
BigDawwg6969
Aug 13, 2005 05:16 AM
