autometer tachometer question...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven Poljak »</TD></TR><TR><TD CLASS="quote">does the blue wire behind the cluster for the MPH gauge the same one used to cnnect the RPM gauge to</TD></TR></TABLE>
Yes, you can use this wire.
Before you buy another ricer mod, maybe you should invest in a Helms manual so you don't have to waste our time asking so many questions that could be answered with the turn of a page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven Poljak »</TD></TR><TR><TD CLASS="quote">so the blue wire will be going to both gauges.. this is okay to do u said right??
Yes, it's fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven Poljak »</TD></TR><TR><TD CLASS="quote">a what of kind of manual</TD></TR></TABLE>
Helms (brand) manual. It has everything to repair your car.
Yes, it's fine.
On my ground wire black with gray stripes going to the radio i puleld on it and i doint know where the other end is at. my dash lights and tail lights havent come on since i before i pulled on it. i think it would be unplugged because now the cluster is not working period. It doesnt show any temp speed or gas. do all the things share the same black ground wire.
my cluster isnt working right now, but i did have the tachometer on and connected to the blue wire which connects to behind the mph gauge, it didnt show anything.
the mph gauge also has a black n yellow and black wire. which i presume is power and ground.
I don't think you wired everything correctly. Did you cut the looped wires on the back of the tach? You might have blown a fuse when installing the tach.
i had not tested the cluster before i tried the tach so i dont know what may of messed it up. but the green wire has no power coming from it, neither does the yellow. the red and black have been power and ground on the tach. so i was thinking that i didnt ruin the cluster but why isnt it working? i had unplugged the 4 cables from the cluster and put them back in didnt seem like any of the gauges worked.
also with my cluster light problem the fuse keeps blowing i dont know where the loose wire would be any ideas
crazyhorse2011
13
Aug 20, 2016 06:42 PM
BasedDean
Feb 18, 2014 06:52 PM
Mac Listo
Apr 22, 2008 06:03 PM
hondaZvic
Audio / Security / Video
18
May 9, 2007 09:34 PM
SHIFKU(EF9 HOPE FUL)
Sep 21, 2005 08:02 AM
