coolant burning. simple question
Old Oct 5, 2006 | 05:26 PM
92ehatch's Avatar
Default coolant burning. simple question
ok i have a d16z6 in another car that im swapping into mine. the motor has a new headgasket but its burning coolant (i didnt put the headgasket on)
i was wandering.. besides the headgasket or a cracked block, are there any other ways coolant can enter the combustion chamber.
i plan on changing the headgasket anyways, since it coulda been done wrong, and inspecting the block. but just need to know if there is anything else i should look for (as far as coolant burning)
tia
Old Oct 6, 2006 | 04:45 AM
92ehatch's Avatar
Default Re: coolant burning. simple question (92ehatch)
bump for an easy question
what other ways can coolant enter the combustion chamber so i know what to look for.
my first swap/engine teardown. a learning experience for me. help a brother out
Old Oct 6, 2006 | 04:48 AM
-DC2-'s Avatar
coolant lines routed improperly or broken sensors resulting in dumping coolant into the IM thru the throttle body or IACV or FITV
Old Oct 6, 2006 | 04:49 AM
92ehatch's Avatar
ill add a little more.
engine runs strong.
head has ben milled .001
it burns coolant after first startup and when it idles. after driving for mabey 5 min it doesnt burn anymore.
92ehatch's Avatar
Default Re: coolant burning. simple question (-EH3-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -EH3- &raquo;</TD></TR><TR><TD CLASS="quote">coolant lines routed improperly or broken sensors resulting in dumping coolant into the IM thru the throttle body or IACV or FITV</TD></TR></TABLE>
welll the FITV has been removed because it has a skunk2 manifold with a str 68mm TB
can coolant enter through the IACV? cause i have an extra one from the d15 thanks, looking for all possibilites
Old Oct 6, 2006 | 07:04 AM
black_EM1's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">
can coolant enter through the IACV? cause i have an extra one from the d15 thanks, looking for all possibilites</TD></TR></TABLE>
Technically, yes it can. I know some people who have the coolant lines to/from the IACV blocked off.
Old Oct 6, 2006 | 08:55 AM
w0ng_sta's Avatar
Default Re: coolant burning. simple question (black_EM1)
intake manifold gasket... on a b16 there are two small ports on the passanger side of the block. these pass through the intake manifold gasket into two spouts( .. SPOUTS not nipples haha) where coolant hoses connect to. if your intake manifold gasket is not seated correctly, or has leftover gasket on it it is possible for the coolant to leak and get sucked into the cylinders where the runners should be connecting.
also like the other guy said. you might have some coolant/vaccum lines confused..
how do you know ur burning coolant? white smoke?
Old Oct 6, 2006 | 02:46 PM
92ehatch's Avatar
Default Re: coolant burning. simple question (w0ng_sta)
yup pulled the IM gasket off and looked at where the coolant passage is. it appears that it was leaking from there.
it was a felpro gasket
im gonna get some honda oem and not pull the head. hopefullly that was it, if not then ill just pull the head and replace the headgasket later
Old Oct 6, 2006 | 05:44 PM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w0ng_sta &raquo;</TD></TR><TR><TD CLASS="quote">
how do you know ur burning coolant? white smoke?</TD></TR></TABLE>
white and sweeeeet smelling. definately coolant.
i looked at the motor (i didnt put this thing together, someone else did) and i didnt see any coolant/vacuum lines mixed up.
have yet to pull the IACV off the intake manifold.
the headgasket is new, so i dont wanna pull the head if i dont have too. but then again, it would be easier to pull it and replace the headgasket now than after i put the motor in my car and find out it still burns coolant.
unfortunatly this is my first swap..im very limited on my knowlege and only have my helms and HT for information. i dont wanna deal with timing and all that crap after pulling the head.
thanks for the replies guys, will see how it goes
Old Oct 6, 2006 | 10:34 PM
w0ng_sta's Avatar
well im glad you found a leak .. hopefully that was the problem.. the iac doesnt really leak coolant really.. the hoses on the bottom just provide coolant flow to a very small area in the iac so the iac knows the temperature of the coolant and can adjust. as for your IM gasket.. i would just buy a hondata heatshield gasket.. reusable and will shape to fit if tightened down all the way... also give some distance between your im and head reducing temperatures
Old Oct 6, 2006 | 11:09 PM
F20Cteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
Technically, no. The IACV is a cast piece of aluminum with a recessed area in the bottom. The cover is steel and has the two nipples on it.
Unless the aluminum has corroded a lot, I MEAN A LOT, it is ot going to leak.
The FITV can leak because there are o-rings that seal the valve. The IACV has nothing of the sort.
Anyway, ya, check the IM gasket.
&gt;&gt;&gt;&lt;&lt;&lt;
Old Oct 7, 2006 | 01:04 AM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">yup pulled the IM gasket off and looked at where the coolant passage is. it appears that it was leaking from there.
im gonna get some honda oem and not pull the head. hopefullly that was it, if not then ill just pull the head and replace the headgasket later</TD></TR></TABLE>
i've never had a problem with a felpro gasket, often times i like the construction of felpro over oem stuff.
quikflip27
Mar 4, 2009 11:10 AM
kodarren
Oct 11, 2006 06:39 PM
tallyBanned
Aug 18, 2006 08:50 AM
george34
May 7, 2006 07:09 AM
david90
Aug 26, 2003 09:28 AM
