Motor Knocking at 2100 RPM's and up
Old Oct 5, 2006 | 04:07 PM
IAWIaccord's Avatar
Default Motor Knocking at 2100 RPM's and up
So ive read all the accord forms about this problem but now i have to ask what else could be wrong I have a 1990 ex and something's knocking in the head i have tried adjusting the valves and did a compression test. What could it be; im running full sythetic oil and not burning anything nor is any coolant disapearing. Replaced the Raditor,trany, distributor, wires, plugs, and have a short ram intake with all the vaccuem lines hooked up along with headers. if anyone has any ideas or lives near milwaukee let me know.
Old Oct 5, 2006 | 04:20 PM
Ross 2.0's Avatar
In a Junkyard near you.
Sounds a lot like a rod knock to me
Old Oct 5, 2006 | 06:41 PM
IAWIaccord's Avatar
I dont think thats it but how would I check that out, and wouldnt that cause a little bit of a rougher ride
Old Oct 6, 2006 | 04:03 AM
Ross 2.0's Avatar
no so much. If it's slight it will just make noise and you will notice a loss of power. But if you have adjusted the calves and they are correct that makes me think rod knock
Old Oct 6, 2006 | 05:34 AM
patastinky's Avatar
Default Re: (Ross 4107)
higher octane gas?
Old Oct 6, 2006 | 06:49 AM
IAWIaccord's Avatar
Default Re: (patastinky)
I use 93 octane only and I noticed that when the motor is cold its fine only when it heats up does it start it. could I have over tighten the valves, it was the first time I did a valve adjustment but when i did it on 2 out of 4 cylinders there was no drag with the feeler gauge on both intake and exhaust those were the ones i fixed the rest were fine ?
Old Oct 6, 2006 | 03:26 PM
IAWIaccord's Avatar
Default Re: (IAWIaccord)
I re did the valve adjustment today and got the car to stop knocking for about 5 miles but now it has returned just not as loud i think im going to re do it again tommrow and see what happens now that im getting better with a feeler gauge or am i just waisting my time please let me know
Old Oct 9, 2006 | 12:07 AM
Jmumblez2001's Avatar
my 1994 accord does the same thing manual tranny. AT 2100 rpms it knock but @ higher rpms it stops, been doin it since i had the car got me stupmed
Old Oct 9, 2006 | 02:01 PM
IAWIaccord's Avatar
Default Re: (Jmumblez2001)
yea I dont know what to do at this point im gonna save up some cash and go all motor H22 and run this engine in to the ground
pumpkyn
10
Sep 30, 2006 03:20 PM
cviccoupe
Sep 3, 2006 09:25 PM
s1ngle
Apr 13, 2005 09:49 AM
Charlie Moua
Oct 6, 2002 09:09 PM
hybrid-t
Jun 22, 2001 10:07 AM
