removing a TPS?
Old Oct 5, 2006 | 01:42 PM
itsjdmbradyo!'s Avatar
Default removing a TPS?
So i need to replace my throttle position sensor, how are you susposed to remove them? the little rivvets i dont know how or if im suposed to pop those off? thanks in advance.
Old Oct 5, 2006 | 02:12 PM
Default Re: removing a TPS? (itsJDMbradyo!)
anyone?
Old Oct 5, 2006 | 02:22 PM
philosofy1's Avatar
you have to remove the t/b to apply the right amount of pressure to reomve the screws on the t/b, since they are a bitch you take out.
Old Oct 5, 2006 | 02:49 PM
lemon_juice's Avatar
drill out the rivits, and when replacing the new TPS youll need to re-calibrate it.
easier to go to the junk yard and find a tb with a good tps
Old Oct 5, 2006 | 02:59 PM
poison's Avatar
Default Re: removing a TPS? (lemon_juice)
Grab a dremel, and cut a "slit" into it. Put a flat head screw driver to it, and take it out like a regular screw.
Old Oct 5, 2006 | 03:45 PM
dthug's Avatar
Default Re: removing a TPS? (poison)
its a pita to take off cuz i guess honda didn't want you to remove them in the first place, what i did was get a dremal and cut slits like poison said it was really annoying but try to be careful not to brweak the top of the screw off and leave half in the whole cuz thats what i did
Old Oct 5, 2006 | 06:34 PM
Default Re: removing a TPS? (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Grab a dremel, and cut a "slit" into it. Put a flat head screw driver to it, and take it out like a regular screw.</TD></TR></TABLE> alright thats the route ill take then sounds fairly easy......but whats this about recalibration?
my junk yard doesnt have any b-series motors except for 1st gen LS's.
Old Oct 5, 2006 | 06:37 PM
Crx Jimmy's Avatar
thats weird my b16's tps had it held on by torx screws
Old Oct 5, 2006 | 07:40 PM
Default Re: removing a TPS? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">thats weird my b16's tps had it held on by torx screws</TD></TR></TABLE>it was probably replaced at some point then.
Old Oct 5, 2006 | 08:27 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMbradyo! &raquo;</TD></TR><TR><TD CLASS="quote">it was probably replaced at some point then.</TD></TR></TABLE>
correct. I've also seen a lot of JDM engines that have screws holding 'em in. makes me wonder.
Old Oct 5, 2006 | 09:01 PM
N1 Andy's Avatar
R.I.P. Andy
cut slits in the screws with a hacksaw/dremel anything like stated before, you calibrate it with a voltmeter, measure voltage on the middle wire I believe and it should be .45v at closed throttle and 4.5v at WOT, loosen the screws and twist it until it reads right.
Old Oct 5, 2006 | 09:19 PM
Default Re: removing a TPS? (Slow Jdm EG6)
can you elaborate the "twisting" more please? sorry.
Old Oct 5, 2006 | 09:46 PM
N1 Andy's Avatar
R.I.P. Andy
you have 2 screws, when you loosen them both you should be able to rotate the tps sensor about 1/4 of an inch, the sensor should have slots cut in it that will let you rotate the sensor back and forth to get your proper .45/4.5v reading as stated before. if the reading is .40v at closed throttle for instance, rotate the sensor a tiny bit until you get a reading of .45v, good luck
Old Oct 5, 2006 | 10:55 PM
alright cool.
Old Oct 6, 2006 | 01:36 AM
dthug's Avatar
you can use any b, d, or h series tps
Old Oct 6, 2006 | 06:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">you can use any b, d, or h series tps</TD></TR></TABLE> thanks, i got a good tps on my d16
Old Oct 6, 2006 | 12:36 PM
TriniTech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lemon_juice &raquo;</TD></TR><TR><TD CLASS="quote">drill out the rivits, and when replacing the new TPS youll need to re-calibrate it.
easier to go to the junk yard and find a tb with a good tps</TD></TR></TABLE>
Old Oct 6, 2006 | 12:45 PM
Slopoke's Avatar
correct. I've also seen a lot of JDM engines that have screws holding 'em in. makes me wonder. </TD></TR></TABLE>
Every JDM motor that I have ordered or installed has had screws instead of rivits.
Weird.
NvBiker1
Apr 8, 2013 06:32 AM
peAches yO
Nov 9, 2009 08:05 AM
1meangsr
Aug 26, 2003 12:24 AM
ih8danoles
Apr 21, 2003 12:21 PM
rasta420
17
Apr 11, 2003 02:24 PM
