What are my options? (BLOWN LS///VTEC!!!)
Old Oct 5, 2006 | 09:26 AM
turboeg831's Avatar
Default What are my options? (BLOWN LS///VTEC!!!)
Well, i found out what was wrong with my car...after hearing it tick for awhile, and unbeknownst of my problems, totally ignoring...the car finally croaked. from what i can tell, the block is shot, maybe rods or rod bearings. the crank pulley doesnt budge...so i guess im right. my question is, what are my options now? diy and swap the LS? how hard is that? what if its only internals, should i just do replace the internals myself? urh...what else?
Old Oct 5, 2006 | 10:45 AM
turboeg831's Avatar
BUMPITY!!!!
Old Oct 5, 2006 | 10:47 AM
DXH's Avatar
DXH
Default Re: What are my options? (turboeg831)
dude LS blocks are cheap you can the entire block for like 6 or 700 rebuilding will suck your money
Old Oct 5, 2006 | 11:34 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg831 &raquo;</TD></TR><TR><TD CLASS="quote">Well, i found out what was wrong with my car...after hearing it tick for awhile, and unbeknownst of my problems, totally ignoring...the car finally croaked. from what i can tell, the block is shot, maybe rods or rod bearings. the crank pulley doesnt budge...</TD></TR></TABLE>
what exactly happend? why don't you diagnose the problem before seeking a recommended course of action? keep us posted.
Old Oct 5, 2006 | 11:36 AM
EJgsr's Avatar
Default Re: What are my options? (thahuhstunna)
b20.
Old Oct 5, 2006 | 02:52 PM
turboeg831's Avatar
well, for reference and starters, this is what happened throughout the course of the week...
https://honda-tech.com/zerothread?id=1769305
what now???
Old Oct 5, 2006 | 04:11 PM
Default Re: (turboeg831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg831 &raquo;</TD></TR><TR><TD CLASS="quote">well, for reference and starters, this is what happened throughout the course of the week...
what now???</TD></TR></TABLE>
i'll give you the same advice i gave another guy who had the same problem. take off your oil pan, and look in there for small flakes of fresh metal. for what ever reason, car burning oil or a leak, it seems like the level got too low and your crank shaft is chewed up. check that first, and we'll go from there. keep me posted.
Old Oct 5, 2006 | 04:39 PM
turboeg831's Avatar
thank you very much, ill check it out tonight...
dthug's Avatar
Default Re: (thahuhstunna)
b20vtec ftw!
Old Oct 5, 2006 | 04:48 PM
Slamaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">i'll give you the same advice i gave another guy who had the same problem. take off your oil pan, and look in there for small flakes of fresh metal. for what ever reason, car burning oil or a leak, it seems like the level got too low and your crank shaft is chewed up. check that first, and we'll go from there. keep me posted.</TD></TR></TABLE>
X2
Squigglez
Apr 20, 2008 04:51 PM
BlakeJ53
Sep 4, 2007 03:59 AM
crxx
10
Mar 3, 2007 08:13 AM
WykidEH
Oct 18, 2001 11:34 AM
