Boosted crank
Old Sep 3, 2007 | 01:03 PM
BlakeJ53's Avatar
Default Boosted crank
I have a 82 mm Benson GSR block with JE pistons and Eagle rods. I was getting my block assembled by a very trusted machine shop. They balanced and polished my crank. They called me and said there were scratches in the journals. So I asked him if he would run it in one of his cars and he said not with the amount of power I want (500-550 whp). So I was wondering how a balanced LS crank and my bearings would hold up to that kind of horsepower. This is my daily driver and I want it to handle the abuse and all the high reving. Would this be a wise choice or should I hold out for a C1 or C5 crank that I can't find? Thanks, Jordan.
Old Sep 3, 2007 | 01:32 PM
Muckman's Avatar
Moderator in Chief
Default Re: Boosted crank (BlakeJ53)
They couldnt polish the scratch out? But to answer your question LS/CRV cranks kick ***. 1.8mm longer stroke than GSR/ITR and its lighter too. It wont limit your rev limit.
Make sure you get LS lenth rods and LS rod bearings bc they are different.
Old Sep 4, 2007 | 03:37 AM
Topdawgg's Avatar
dont need the C1 or C5 crank.. just find a better condition LS
I used a crank that had been sittin in a block outside for a while... when i had it checked by the machine shop, they said it was fine and they polished it for me..
just shy of 500whp/340 tq for 15000 miles now at least, no problems at all
Old Sep 4, 2007 | 03:51 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Topdawgg)
the ls will work, i didnt have an ls crank, and already had carrillo's and wasnt buying another set of rods.
i had the same problem, the crank i sent to ERL said wouldnt poilsh out, and the power i wanted to make they didnt recomend a .010 .010 turn down. i found another stock crank gsr crank and making 710whp.
Old Sep 4, 2007 | 03:59 AM
Topdawgg's Avatar
98% of people on here will say they trust nothing but OEM
tdrewd
Sep 28, 2012 10:17 AM
Gaspari
Sep 14, 2010 01:42 PM
jordan2305
Dec 11, 2007 04:47 PM
aser1z
Jul 28, 2005 06:47 PM
jdmsijdm
Dec 19, 2004 10:53 AM
