Clutch torque specs..
well im doing my own clutch in my car with my buddy and i dont have an owners manual. i was wondering if anyone can tell me the flywheel spec and the clutch spec too. thanks
dan
dan
if you got a 4th gen go on the autozone website the guide on there is decent enough for a clutch. and if you got a fifth gen go to hondahookup
If so, the torque specs are below. To remove and install the bolts on the pressure plate and flywheel(if your removing it) do it in a crisscross pattern. Make sure you break all the bolts off first then start loosening them up little by little in a crisscross patter. or else you will warp the pressure plate and/or flywheel.
