LS VTEC 12.1 compression, Timing recommendations
Guest
Posts: n/a
Just wondering what you high compression guys have your timing set up as???
I have an LSVTEC 81mmx95mm fully built bottom end, p72, stock fuel setup. My timing is currently retarded all the way, it runs great, but I just want to make it run better.
Any ideas, suggestions would be greatly appreciated.
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">take it to a dyno and get it tuned dude. dont waste your time.</TD></TR></TABLE>
x2....especially with that compression and 95 crank.btw is this your dd?
thats good. post up dyno sheet after you get that beast dyno. and im curious how does the the car drive dd with that 95 crank?
Guest
Posts: n/a
Hey guys, I just looked this up on another thread, and the guy recommeded running some NGK spark plugs on and ls-vtec with 12.1 compression, he recommended running a colder range. the guy mentioned that it wouldn't detonate.
its under this thread
https://honda-tech.com/zerothread?id=1771274
My current timing is retarded all the way(to prevent detonation). I know I know, I am going to get it tuned wed. I'll keep you guys posted.
what do you guys think of this. One of my mechanic buddies says this is horseshit.
.RTErnie
Nov 29, 2005 10:14 AM
