96 gsr brake swap into 91 crx
Old Oct 3, 2006 | 09:55 PM
webrex's Avatar
Default 96 gsr brake swap into 91 crx
i need some info on this swap..got the f&r brakes with brembo rotor's. should i do the swap? i got the stock dis brake on it right now
Old Oct 4, 2006 | 05:10 AM
ryanplayjoint's Avatar
Default Re: 96 gsr brake swap into 91 crx (webrex)
If you already have a F & R disc setup it is a remove and replace procedure. If you have rear drum you will need rear SI brake hoses and 1-2 si/e-brake cables depending on you e-brake holding requirements.
Old Oct 4, 2006 | 05:11 AM
Default Re: 96 gsr brake swap into 91 crx (ryanplayjoint)
Oh yeah, your alignment will be all jacked up after the spindle and trailing arm swap.
Old Oct 7, 2006 | 02:28 AM
webrex's Avatar
cant i just bolt the calipers and rotors up front ?
Old Oct 7, 2006 | 06:12 PM
v.i.massive's Avatar
from the info i have gathered if its anything like the 90-93 integra brakes into a 88-91 crx you can use the front spindle and bolt right up, but if you use it without the integra master cylinder and booster the brake wont be right( like stock felling when you press the brake) someone correct me if i'm wrong dont want to give bad info
Old Oct 7, 2006 | 06:14 PM
this might help https://honda-tech.com/zerothread?id=1764716
Old Oct 9, 2006 | 03:45 PM
webrex's Avatar
Default Re: (v.i.massive)
hey thnx. i went to the wreckenyard the oth
Old Oct 9, 2006 | 03:54 PM
webrex's Avatar
Default Re: (webrex)
**** ..my bad. went to the wreckenyard, got me a 91ex hub and knuchel for 30 bucks. i install one of the 96 gsr calipers on there and it fits great. when i took a closer look at the brembo rotors, not sure but i think it's 11in. it has the number 11 DA 19mm making on it. does the 96 gsr calipers fit 11in rotors?
88SeeOurEx
11
Oct 28, 2008 02:13 PM
bl_harden
11
Jul 5, 2006 02:07 PM
95_red_dc
Jun 6, 2006 09:48 AM
i heart honda
10
Jan 31, 2006 06:52 AM
91sifreak
Aug 30, 2001 12:56 PM
