CEL code 14 THE IAV!! how do i fix it?
Old May 1, 2002 | 10:15 PM
allmotor2000's Avatar
Default CEL code 14 THE IAV!! how do i fix it?
okay heres the thing my 2000 Si has 12000 miles on it. THe other day the CEL light came on and my idle is a bit high now. sometimes around 13-1400 RPMs. When i give it some gas right under 2000 rpm it would lope....(goes up and down really faast....) and its buggin the **** out of me. can anyone help?
Old May 1, 2002 | 10:20 PM
aeolus's Avatar
Default Re: CEL code 14 THE IAV!! how do i fix it? (allmotor2000)
Have you messed with the car lately in anyway?
Old May 2, 2002 | 06:33 AM
nope...nothing at alll. the only thing that was changed was the airfilter...but even when i change it back to stock....it still does that. I am clueless....help me please..
Old May 2, 2002 | 06:47 AM
StyleTEG's Avatar
You can pull the IAC off and clean it with some carb cleaner, if that doesn't work you probably need a new one.
Old May 2, 2002 | 12:47 PM
Perfectionist's Avatar
With the engine not running, ignition on, unplug and plug back in the IACV connector. You should hear a click. If not, check for about 12 volts at the connector. If that's OK, the IACV is most likely toast. If it does click, might need cleaning. You could try a total reset of the ECU by disconnecting the neg battery cable or pulling the ECU fuse for 10 seconds. BTW, you'll need your radio code if you've got a stock unit to reset the radio. After everything is back together, start the car and let it idle about 10 minutes without touching the gas pedal.
Old May 2, 2002 | 03:38 PM
Default Re: CEL code 14 THE IAV!! how do i fix it? (Perfectionist)
hey thanks alot guys. OKay this is what ive done so far. I went and check if it clicked and yes it did click. I did the voltage check and see if theres power coming from it. I did and it said about 11-12. I tried cleaning the connections or watevers...Now im gonna go drive it for awhile see whats gona happen. Thanks alot guys!! ho wmuch is a new one anyways?
Old May 2, 2002 | 06:06 PM
okay i left the car on for 10 minutes and nothing...no light or anything. I drove it for about 15 minutes and the light came on again. What is up with it now? SAme code...same thing happening. Is there anything else i can do to fix this? I was happy for awhile that it was gone but now its the same old thing...help me please!!
Old May 11, 2002 | 12:19 PM
b18c1-ek's Avatar
try to swap another IACV in that's known to be working. It only takes 5 minutes to replace.
Old May 11, 2002 | 02:37 PM
B18C-RnVA's Avatar
New User
Default Re: CEL code 14 THE IAV!! how do i fix it? (b18c1-ek)
****, join the club homie, me and civicryda are having the same problems i replaced mine and i still get the code and a fucked up idle
Old May 11, 2002 | 09:12 PM
b18c1-ek's Avatar
Default Re: CEL code 14 THE IAV!! how do i fix it? (B18C-RnVA)
at this point, check the wiring, and if that doesn't help, swap ECU's with someone and see if the code is still there...
TypeR-Em1
May 26, 2013 08:52 PM
SoCalRyder7
Feb 21, 2012 02:08 PM
freshvibes
Feb 27, 2009 09:45 PM
GeorgeY
Jun 29, 2003 08:59 AM
oi-punx
Dec 14, 2002 10:00 AM
