crank and rod bearings....... all the same for B- motors?
Old May 1, 2002 | 09:23 PM
eddie1681's Avatar
New User
Default crank and rod bearings....... all the same for B- motors?
Hi
I have the Jspec B16a, can I use the 99-00 Si bearings?
Old May 1, 2002 | 10:11 PM
allmtr's Avatar
Default Re: crank and rod bearings....... all the same for B- motors? (b20z)
i dont see why not. its all the same.
Old May 2, 2002 | 12:48 AM
Kamin's Avatar
Default Re: crank and rod bearings....... all the same for B- motors? (allmtr)
um i thought all motors had diffrent rod bearings?
like if you compare 2 b16's they have diffrent bearings
maybe im wrong.
happened before (need sleep, tired.)
Old May 2, 2002 | 06:49 AM
Trey's Avatar
25 Year Member
Default Re: crank and rod bearings....... all the same for B- motors? (KAMiN)
Just read the codes stamped in the rods and crank and block to get the correct bearings from Honda Parts.
If you have no clue what I'm talking about, buy a Helms.
http://www.helminc.com
Old May 2, 2002 | 08:53 AM
rainforest's Avatar
Default Re: crank and rod bearings....... all the same for B- motors? (Trey)
or you could plasti gadge it and see what bearsing might give better (bigger) oil clearances
Old May 2, 2002 | 09:04 AM
allmtr's Avatar
Default Re: crank and rod bearings....... all the same for B- motors? (rainforest)
yeah, just plastigage it.
Old May 2, 2002 | 02:41 PM
dohcsideSi's Avatar
1st gen b16a and b16a2/3 use different bearings, i pretty sure sir2 b16's use the us spec bearings though.........b18a/b and b20b/z are the same but will not fit vtec motors, b18c/1 and b18c5 are also the same but do do fit b16's.
Old Aug 27, 2007 | 01:47 PM
IceySC's Avatar
Default Re: crank and rod bearings....... all the same for B- motors? (dohcsideSi)
im bring this back from the dead. im almost done with my mtor and i needed some bearings i have a b18c1 with eagle rods and wisco pistons 81.5 and i check with acrua and got the part number and i called honda and gave them the part number and honda told me the part number cross reference with the part number from acura and the parts guy at honda said it would work . but he's just a parts guy. so want do you'll think i do know that there different color codes . if anyone could please help me out asap thank you very much.
Old Aug 27, 2007 | 05:41 PM
IceySC's Avatar
Default Re: crank and rod bearings....... all the same for B- motors? (eddie1681)
please
Wytek9
Jul 27, 2010 05:12 AM
95dxsir2
Jan 10, 2010 02:53 PM
SOHCD16y8
May 21, 2005 12:32 AM
v4lu3s
Jul 26, 2004 11:25 AM
Nextelbuddy
Jan 9, 2004 10:12 PM
