4 bolt vs. 5 bolt
Old Oct 1, 2006 | 03:44 PM
TurboEM1's Avatar
Default 4 bolt vs. 5 bolt
Hey guys. I am piecing together a turbo kit. I will be using a garrett t3/t4 57 trim .63 a/r turbo. What is the difference between the 4 and 5 bolt. The 5 bolt seems to be a little more money. Is it better performance? fitment? Spool? anything?
Thansk
Old Oct 1, 2006 | 04:45 PM
JSPECSIR's Avatar
Default Re: 4 bolt vs. 5 bolt (TurboEM1)
no it just takes a different exhaust flange on your downpipe thats all. the 5 bolts were designed so that a flapper housing can bolt on and use an internal gate if you choose to do so.
Old Oct 1, 2006 | 05:31 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 4 bolt vs. 5 bolt (JSPECSIR)
5 bolt housings are generally larger overall.
the 4 bolt housings have a smaller footprint
4-bolt is to be used with an external wastegate
5-bolt has the option of using an interal flapper if the housing was cast with the flapper hole
Old Oct 1, 2006 | 05:58 PM
nebulight's Avatar
Default Re: 4 bolt vs. 5 bolt (wantboost)
I've also heard that the 4 bolts will flow better because there is less restriction with the flapper hole in the turbine housing. Now it might just be a small amount, but any little bit helps. I always use 4 bolt.
Old Oct 1, 2006 | 05:59 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 4 bolt vs. 5 bolt (nebulight)
eh, probably but its very very minimal.
my 5 bolt housing is sans wg hole
ryguy2588
Jun 10, 2011 06:33 PM
StreetEG
Jul 27, 2006 06:21 PM
gyrluknouwantme
Nov 6, 2005 10:23 PM
H22coupe
Nov 20, 2002 01:59 PM
