T4 manifold fitment ? (using t3/t4 turbo) w/ making a flange
Old Oct 1, 2006 | 01:47 PM
spoolingb20's Avatar
Default T4 manifold fitment ? (using t3/t4 turbo) w/ making a flange
Could I use a T4 manifold that I can get a killer deal on w/ a T3/t4 turbo if I machine a flange that would go between the turbo and manifold to make them fit basically have the flange match up with the set of bolt holes on the exhaust mani and then drill and tapp another set of holes smaller to fit to the t3/ t4 turbo part.
Would this work and are there any cons to doing this.
Old Oct 1, 2006 | 03:41 PM
Default Re: T4 manifold fitment ? (using t3/t4 turbo) w/ making a flange (spoolingb20)
anyone
Old Oct 2, 2006 | 04:05 PM
Default Re: T4 manifold fitment ? (spoolingb20)
anyone know this.... application will be on a 2g eclipse...
Old Oct 2, 2006 | 07:16 PM
turtle-eg's Avatar
You can make a flange or buy one that adapts the t3 turbo to a t4 flange. The only problem is, if it's a ram horn manifold, the turbo would probably hang too low for the oil return.
Old Oct 3, 2006 | 05:17 AM
Default Re: T4 manifold fitment ? (turtle-eg)
well if it is just a cast mani; to be exact its the rev hard mani, you think that it will sit high enough for the oil lines,
BOOSTEDk24a4
Jun 25, 2007 09:51 AM
wrx'n you
Nov 24, 2006 05:26 PM
ITS_Dunn
Feb 1, 2006 07:29 PM
EK k kay
Sep 30, 2005 01:51 PM
servion
Oct 1, 2002 11:56 AM
