why am I boosting different pressures in different gears?
Old Sep 30, 2006 | 09:41 PM
motormike40's Avatar
Default why am I boosting different pressures in different gears?
In 2,3,4 gear im boosting 10 pounds, but when Im in 5th and boost it will hit 10. My engine is turbo ls, ls tranny. dsm 450 injectors, t3. ran with uberdata.
Old Sep 30, 2006 | 09:47 PM
B18 CYA's Avatar
lol that doesn't make sense. u boost 10 in all gears? whats wrong with that lol
Old Sep 30, 2006 | 09:48 PM
Tornadom's Avatar
Default Re: why am I boosting different pressures in different gears? (motormike40)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">In 2,3,4 gear im boosting 10 pounds, but when Im in 5th and boost it will hit 10. My engine is turbo ls, ls tranny. dsm 450 injectors, t3. ran with uberdata. </TD></TR></TABLE>
Your post body contradicts your title? Unless of course first gear differs in boost pressure. If this is the case, it may be advantageous to include it next time. The more information that you can provide us, the more accurate, and prompt responses you will receive.
Old Oct 1, 2006 | 07:02 AM
Turbo-LS's Avatar
1-2 gear might boost less then 3-4 gear because of the amount of load on the engine is much less in 1-2 gear compared to 3-4-5 gear
but yeah your saying different boost pressure in the title then saying same boost pressure, explain better
Old Oct 1, 2006 | 08:15 AM
Oh hell I just caught that. I meant 2nd im pushing 4 3 im pushing 5 4 7 psi, and 5 10.
Old Oct 1, 2006 | 08:36 AM
whiteef8's Avatar
Default Re: (motormike40)
somewhat normal
not so much on the ls trans tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS &raquo;</TD></TR><TR><TD CLASS="quote">1-2 gear might boost less then 3-4 gear because of the amount of load on the engine is much less in 1-2 gear compared to 3-4-5 gear
ringgold
May 11, 2004 09:38 PM
eghatchproject
Feb 21, 2004 04:57 PM
Talon12bp
Dec 2, 2003 07:33 PM
92HB_HB
Mar 10, 2002 06:32 PM
DamonBoost
Nov 22, 2001 01:14 PM
