white smoke when in boost. compression consistent
I thought i had blown my headgasket after white smoke started shooting out of my exhaust while gunning it. Did a compression test today and it was 175 across all 4 cylinders on a cold engine.
The 3 things that could explain the white smoke are headgasket, bad rings or blown turbo seals. I feel like i can eliminate the first 2 due to the compression test and conclude that the smoke is coming from the turbo. Any objections?
Thanks ahead of time for any input.
-Johnny.
-Johnny.
its the head gasket if you are getting white smoke! if you dont have head studs you should really think about getting some and use a really good tourqe wrench (snap-on, craftsmen) heat soke them then re-tourqe for maximun seal
I am seriously doubting the head lift. Probably a turbo seal issue. People always say they are seeing white smoke, but half the time burning oil smoke looks very white. It will have a bluish tint, but can be hard to see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">I am seriously doubting the head lift. Probably a turbo seal issue. People always say they are seeing white smoke, but half the time burning oil smoke looks very white. It will have a bluish tint, but can be hard to see.</TD></TR></TABLE>
I agree. Perform a lead-down test to find the cause.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix1 »</TD></TR><TR><TD CLASS="quote">
I agree. Perform a lead-down test to find the cause.</TD></TR></TABLE>
Compression is consistant.. Only smokes in boost. Leak down test isn't going to show crap. Now a block tester on the other hand will verify if its the headgasket or not.
did another compression test yesterday but with fully warmed up motor this time. 195-190-190-185.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">how much hp are you making? on how much psi?</TD></TR></TABLE>
this happened a week b4 i was getting it tuned. been running a friends tune with same exact car/setup as mine temporarily. so no dyno numbers. 7psi
btw i produced some smoke for a friend last night and he said it definitely smelled like oil and not coolant, he could always be wrong but ill assume he knows how to distinguish.
