Bored Out Throttle Body
Old May 1, 2002 | 03:22 PM
luc_cairo's Avatar
Default Bored Out Throttle Body
Should i expect my idle to change if i was to bore out my throttle body???
Old May 1, 2002 | 03:24 PM
hybridreams's Avatar
Default Re: Bored Out Throttle Body (luc_cairo)
no
Old May 1, 2002 | 03:30 PM
luc_cairo's Avatar
Default Re: Bored Out Throttle Body (hybridreams)
do you know the exact details as to what happens when boring out the throttle body.
Old May 1, 2002 | 03:32 PM
Rocket's Avatar
If done properly, No. But if it's not done properly your idle may be high.
Old May 1, 2002 | 03:37 PM
your throttle has a "peppier" feel to it
Old May 1, 2002 | 03:50 PM
luc_cairo's Avatar
smooth
Old May 1, 2002 | 10:28 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
get a bigger one 70MM = ownz j00
Old May 2, 2002 | 01:59 AM
b19coupe's Avatar
Default Re: Bored Out Throttle Body (dLo GSR)
I don't know if it's typical, but when I went from a Type-R 62mm throttle body to an Ericks Racing 70-68mm (tapered) throttle body, my wheels started to spin when VTEC kicked in on dry pavement in 1st gear. It did not do that before.
Old May 2, 2002 | 04:33 AM
EE_Chris's Avatar
Default Re: Bored Out Throttle Body (b19coupe)
So long as the throttle plate and bore make there 'appropriate' contact/seat....you should be fine. If this contact/seat changed, your idle will go high. Its in the same respect as you turning the throttle stop screw (not the idle air bypass). So if you bore, keep this in mind....if you just bought another one altogether, I wouldn't worry.
I'd venture a guess, but for an Erik's Racing 70mm T-Body...he also uses an enlarged throttle plate....but thats just a guess on my part.
If thats not the case, someone mind elightening me.
Old May 2, 2002 | 06:33 PM
b19coupe's Avatar
Default Re: Bored Out Throttle Body (EE_Chris)
Throttle plate on ER's throttle body is 68mm.
hkrichard
Apr 27, 2008 06:03 PM
95_red_dc
Sep 11, 2006 09:47 PM
bootlegtrader
Feb 5, 2006 09:04 AM
Initial DA6
Aug 29, 2002 03:24 PM
