Oil filter change? how often?
Old May 1, 2002 | 03:12 PM
ITR Demon's Avatar
Default Oil filter change? how often?
should i change my oil filter everytime i change the oil on my ITR? if not, how often?
Old May 1, 2002 | 03:13 PM
CPR's Avatar
CPR
Default Re: Oil filter change? how often? (ITR Demon)
Change it everytime you change your oil.
hungsteR's Avatar
I change every time. I'm sure everyone else does too.
Old May 16, 2002 | 05:10 PM
Wormaker's Avatar
New User
Default Re: Oil filter change? how often? (hungsteR)
ooops..I made a mistake changing my oil..I replaced the oil filter and everything..but I just remembered to initially put oil around the new oil filter before screwing it on...oil level is fine on the gs-r..should I be worried...DOH!...I'm an idiot!
Old May 16, 2002 | 05:12 PM
t's Avatar
t
Default Re: Oil filter change? how often? (Wormaker)
you will be fine
Old May 16, 2002 | 05:23 PM
SurferX's Avatar
Default Re: Oil filter change? how often? (t)
Hey I don't know if you guys know this, but I just figured it out changing my oil on my Type R the other day. On my Integra LS I used to always have to reach from the bottom of the car to get the oil filter so I habitually did it on the R. But I realized the ITR's intake manifold is much shorter and leaves room so you can actually get to it from the top of the engine. Oil changes much easier for me now yay!
Old May 16, 2002 | 06:35 PM
seek167's Avatar
Default Re: Oil filter change? how often? (SurferX)
is there a trick to not get oil down the back of the motor, when changing the filter. i drill a hole in it let it drain still doesn't not good enough .. any suggestions
Old May 16, 2002 | 06:42 PM
01TypeR680's Avatar
New User
Default Re: Oil filter change? how often? (seek167)
use a rag or you could always pull your engine to change the oil -rob
Old May 16, 2002 | 07:12 PM
Willard's Avatar
Take a 1/2 gallon milk jug and use a knive to cut the side (and bottom) off of it. Leave the opening intact (to direct oil into the pan.
Slid the cut jug under the filter (up to the oil cooler) and loosen the filter. After the oil is finish draining.... remove and wipe.
Will
-who has not yet droped oil in his CV shaft or back of block area.
Old May 16, 2002 | 07:40 PM
seek167's Avatar
Default Re: Oil filter change? how often? (Willard)
thanks
holmesnmanny
Dec 10, 2009 03:14 AM
kidcool1977
Oct 27, 2008 05:40 AM
Floyd
Sep 23, 2003 07:08 AM
mr poo
Aug 4, 2003 04:38 PM
