Code 41?
Old May 16, 2002 | 06:14 PM
Casey's Avatar
Default Code 41?
My car is throwing a code 41. SGT said it was due to the 02 sensor on the header, but it is in place and the plugs are connected, so what could it be? thanks. should i try and reset the ecu to see if it still throws the code
[Modified by CWTypeR463, 3:15 AM 5/17/2002]
Old May 16, 2002 | 06:37 PM
Casey's Avatar
Default Re: Code 41? (CWTypeR463)
ok, reset the ecu, no change, still throwing 41
Old May 16, 2002 | 07:40 PM
Cosworth's Avatar
Is the sensor new or did you check it out? carbon deposit?
Old May 16, 2002 | 07:42 PM
Casey's Avatar
Default Re: Code 41? (Cosworth)
i didnt take the sensor out and take a look at it, could quite possibly be the case, can i clean it up or do i need a new sensor
Old May 16, 2002 | 07:57 PM
Cosworth's Avatar
If all the wiring to O2 sensor is good, then you'll most likely need a new OE Honda O2 sensor. You can use a torch blower to get rid of the carbon deposit, but nothing beats a brand spanking new Honda O2 sensor.
btw, are you running mods that made your A:F ratio a lot richer than stock?
Old May 16, 2002 | 07:59 PM
Casey's Avatar
ok, so a blow tourch will work? how much is a new one? yes, the car was running very rich for a while before i had it tuned
Old May 16, 2002 | 08:01 PM
Cosworth's Avatar
I believe new O2 sensor is quite expensive, but don't skimp out on it (read: Bosch or some autostore O2 sensors don't perform like OE Honda one). I think it's priced between $150-$200. Definitely not cheap, but it's a must.
Old May 16, 2002 | 08:03 PM
Casey's Avatar
dammit im going to try and do the blowtourch on it
sick93sol
Aug 5, 2007 03:50 AM
SONIC BOOM
Jun 23, 2006 06:40 AM
vtec25
Mar 14, 2006 02:39 AM
BeavisB16
Apr 29, 2005 03:57 PM
samvtecaccordsport
Jul 18, 2004 02:13 PM
