gsr block b16 head in eg
Old Sep 28, 2006 | 12:59 PM
bustdgst's Avatar
Default gsr block b16 head in eg
just got done doing a gsr block w/b16 head swap into my EG. The difference is phenomenal but I still think its not as fast as it should be. ran my buddy's EG with straight gsr swap and he pulled me by 2 cars...what could be wrong?? Im running a civic SI ECU...should I go with a chipped p28?? I also have a vafc hookep up, and it seems like vtec hits at 48 then at 53. kinda weird!!
Old Sep 28, 2006 | 06:01 PM
so lazy's Avatar
Default Re: gsr block b16 head in eg (bustdgst)
your VAFC settings arent set for your car... so its telling your ecu different readings might be running lean or rich.. take it out and you will know a differene or take it to a dyno and get your car tuned..
Old Sep 29, 2006 | 10:20 PM
Ruben19's Avatar
get it tune with the p28 and the VAFC
Old Sep 30, 2006 | 04:31 AM
Dogginator's Avatar
Daisy... Daisy...
The B16 head lowered you compression ratio and the intake manifold on the GSR produces better low and mid RPM power. What transmissions are you both running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustdgst &raquo;</TD></TR><TR><TD CLASS="quote"> I also have a vafc hookep up, and it seems like vtec hits at 48 then at 53. kinda weird!!</TD></TR></TABLE>
Your crossover may be too early. Does the car lose power at 4800 RPM and then surge near 5300?
Old Oct 2, 2006 | 04:07 PM
Professional Thief's Avatar
Is your buddies car all stock and did you try driving your buddies car and let him drive yours eleminates D.A.F. Theory.
Old Oct 2, 2006 | 04:40 PM
XLR8 GS-R's Avatar
Default Re: gsr block b16 head in eg (Professional Thief)
Any smoke from exhaust? What was ur vafc tuned for before ur new setup? Try advancing the ignition and im sure those 2 car lengths will become -1
Old Oct 3, 2006 | 06:24 PM
bustdgst's Avatar
Default Re: gsr block b16 head in eg (XLR8 GS-R)
is there any webiste I would be able to get base settings for the afc for this set up?? I tried to advance the ignition...(turned towards the front of car??) and no change
Old Oct 7, 2006 | 06:04 AM
XLR8 GS-R's Avatar
Dogginator is right about the vtec crossover and if ur getting black smoke and some back fire ur prolly running too rich. How about you take the afc out- remove all 12v current ithink theres 2 wires? Run your stock ecu ull still be running a little rich but closer to home. keep the ignition advanced and remember to jump the two lead connector by kick panel on p-side! Now rip on it and see what it does.
Modified by XLR8 GS-R at 10:24 AM 10/7/2006
Old Oct 7, 2006 | 01:15 PM
lobudgetr's Avatar
just curious, but wouldn't the GSR manifold creating the better low and mid range power be connected to the seconderys in it that not GSR cars dont have the ability to run anyway?
Old Oct 7, 2006 | 05:19 PM
Riced-EL's Avatar
What are some items needed to get the GSR block onto the b16 head? curious question i kno all B parts fit....but i wanna do tis swap...my b16a2 is juss toooo slow....
Old Oct 7, 2006 | 06:27 PM
XLR8 GS-R's Avatar
Default Re: (Riced-EL)
good question lowbudget but no you would not run the secondaries. Friends used to jam the secondaries open or some would weld them open- they said more flow but who knows. You wouldent need to hook up any sensors or linkage for the secondaries if u had a b16 manifold. I would plug the connector and cap the open vacuum line thou. Riced, you will need nothing
Old Oct 7, 2006 | 10:21 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
you probably lost because the b16 head lowered your compression. people mistake a poor mans type R in place of just slapping on a b16 head on a gsr block.
Old Oct 8, 2006 | 01:56 PM
clayne's Avatar
Default Re: (jdm_dc_fan)
Cmon. This is an ECU issue, not a CR-related one.
Old Oct 12, 2006 | 09:28 AM
kamui's Avatar
ecu or not a b16 head on a stock gsr will run slower then a stock gsr. Also what intake manifold r u running?
Old Oct 12, 2006 | 04:12 PM
clayne's Avatar
Default Re: (kamui)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamui &raquo;</TD></TR><TR><TD CLASS="quote">ecu or not a b16 head on a stock gsr will run slower then a stock gsr. Also what intake manifold r u running?</TD></TR></TABLE>
It won't run significantly slower to cause the original issue. It's a tuning problem here.
EgxHaTcHxGsR
Nov 22, 2009 10:51 PM
Vteckid516
Jun 12, 2007 10:17 AM
jeffsciv23
Oct 5, 2006 07:39 PM
HomeBuilt
Oct 24, 2004 05:00 PM
sikciv666
Mar 12, 2003 01:58 PM
