Dyno Graphs
Old Sep 27, 2006 | 06:51 AM
b16 matt's Avatar
Default Dyno Graphs
B16 block
JE pistons
Eagle rods
stock head
Drag kit
550cc
15psi
300ft lbs of torque on a b16 biatches... Not quite sure why it says ls VTEC cause its def a b16. I built the engine myself. Oh yeah and i gotta get a bigger wastegate spring. As you can see it falling off on the end.
Old Sep 27, 2006 | 06:55 AM
aaronISthrowed's Avatar
Default Re: Dyno Graphs (b16 matt)
nice
Old Sep 27, 2006 | 07:04 AM
AbitAvenger's Avatar
badass
Old Sep 27, 2006 | 08:58 AM
locash's Avatar
What crankshaft?
Old Sep 27, 2006 | 09:01 AM
tony1's Avatar
haha, when your power peaks at 5800 on a b16 you know you've got problems!
Old Sep 27, 2006 | 09:06 AM
M.A.R.C.'s Avatar
Default Re: Dyno Graphs (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">haha, when your power peaks at 5800 on a b16 you know you've got problems!</TD></TR></TABLE>
haha just saw that and then read his W/G problem
Old Sep 27, 2006 | 09:17 AM
komat's Avatar
Default Re: Dyno Graphs (M.A.R.C.)
why would it require a bigger wastegate? or does he mean a bigger spring for more boost?
Old Sep 27, 2006 | 10:11 AM
b16 matt's Avatar
Default Re: Dyno Graphs (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">why would it require a bigger wastegate? or does he mean a bigger spring for more boost?</TD></TR></TABLE>
Yeah the waste gate is opening at the end due to the spring in the wastegate. I only have a 6lbs spring. Anyone know where a good place to pick one up is?
Old Sep 27, 2006 | 10:12 AM
b16 matt's Avatar
Default Re: Dyno Graphs (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">What crankshaft?</TD></TR></TABLE>
Stock b16 stroke. Its a torque monster of a b16 eh?
Old Sep 27, 2006 | 11:29 AM
tony1's Avatar
how far was the boost falling by redline?
Old Sep 27, 2006 | 01:19 PM
boostnubII's Avatar
you put a bigger wastegate spring on that puppy and ur really gonna have a crazy power band... good luck getting that power to the streets... if you can get it to hook... thats gonna be nutz
Old Sep 27, 2006 | 03:45 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16 matt &raquo;</TD></TR><TR><TD CLASS="quote">
small turbos do that
boostedeghatch
19
Aug 11, 2006 08:17 PM
Natural Aspirations
53
Jun 12, 2006 12:48 PM
MidShipCivic
May 14, 2006 05:08 AM
88crxhfb16
Apr 15, 2006 08:42 AM
tbocrx
Oct 7, 2003 09:24 PM
