car over heats
Old Sep 26, 2006 | 10:53 PM
boostedeg9's Avatar
Default car over heats
whats up guys got a 95 civic sedan with a 95LS turbo motor. its got a brand new PWR radiator, thermostat, and water pump but the damn thing still overheats. after driving for 30mins the upper and lower radiator hoses get really hard. and the fan is really inconsitant. can anyone shed some light one this problem.
Old Sep 27, 2006 | 09:16 AM
beaneg6's Avatar
Default Re: car over heats (boostedeg9)
could be a faulty sensor....try changing your coolant temp sensor
Old Sep 27, 2006 | 01:26 PM
shades946's Avatar
Make sure you purge all of the air out of the cooling system after you replaced those parts otherwise it will do what you're describing because of an air pocket in the system. One min temp will be fine, the next you'll be cookin the motor.
Old Sep 27, 2006 | 01:28 PM
philosofy1's Avatar
Default Re: car over heats (shades946)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">could be a faulty sensor....try changing your coolant temp sensor</TD></TR></TABLE>
uh no!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shades946 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you purge all of the air out of the cooling system after you replaced those parts otherwise it will do what you're describing because of an air pocket in the system. One min temp will be fine, the next you'll be cookin the motor.</TD></TR></TABLE>
BINGO! you beat me to the point. the one things people have the tendency to forget when dealing with the cooling system
Old Sep 27, 2006 | 01:53 PM
beaneg6's Avatar
Default Re: car over heats (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">uh no!
uh yes! it very well could be a sensor, i had to recently replace mine, my sensor was faulty, one minute my car would be cold, then the next it would be hot, the sensor was acting up,
Old Sep 27, 2006 | 01:55 PM
philosofy1's Avatar
Default Re: car over heats (beaneg6)
uh yes! it very well could be a sensor, i had to recently replace mine, my sensor was faulty, one minute my car would be cold, then the next it would be hot, the sensor was acting up,</TD></TR></TABLE>
then i would say you were pretty unlucky. i bet 99% of his problem is air in the system.
Old Sep 27, 2006 | 01:59 PM
beaneg6's Avatar
then i would say you were pretty unlucky. i bet 99% of his problem is air in the system.</TD></TR></TABLE>
yeah
Old Sep 27, 2006 | 05:44 PM
Pzn801's Avatar
quick question how you purge???
Old Sep 27, 2006 | 07:54 PM
RED95EG6's Avatar
when you do a cooling system service make sure you leave the **** on the heater side with air off. make sure the fan cycles twice.......make sure no leaks or blown head gasket
Old Sep 27, 2006 | 11:48 PM
boostedeg9's Avatar
Default Re: car over heats (95EG1)
someone also told me that the boost presure could be lifting the head gasket causing the coolant in the block to be under presure. anyone ever heard of this
Old Sep 28, 2006 | 12:48 PM
Pzn801's Avatar
cycle fan how?
Old Sep 28, 2006 | 06:46 PM
boostedeg9's Avatar
Default Re: (Pzn801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pzn801 &raquo;</TD></TR><TR><TD CLASS="quote">cycle fan how?</TD></TR></TABLE> he means let it run till the fan turns on twice.
Old Sep 28, 2006 | 07:13 PM
Ap0c's Avatar
Default Re: (boostedeg9)
try your thermostat... its a cheap part your not getting oil and a coolant mix are you?
Old Sep 29, 2006 | 07:10 PM
Pzn801's Avatar
ah ha, and this is without coolant correct???
Old Sep 29, 2006 | 09:06 PM
boostedeg9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pzn801 &raquo;</TD></TR><TR><TD CLASS="quote">ah ha, and this is without coolant correct???</TD></TR></TABLE>with coolant
Old Sep 30, 2006 | 07:58 PM
shades946's Avatar
The way i get the air out of the system is i have the engine cool and with the radiator cap off i start it and turn on the heat (all assuming you already have coolant in the radiator). While it is warming up i'll add what i need to get the radiator full. While i'm adding i'll run the rpms up to help suck more coolant down and i will also be squeezing the upper and lower radiator hoses to help push out the air. When you get air out, you'll see the coolant bubble if you're looking down where your radiator cap goes on. The squeezing of the hoses is what really seems to get the air out more than anything else. The reving of the motor will suck down what you just filled up so that way you can add more coolant after it has gone down. After a few mins of repeating the process you should be good to go. Oh, and do remember to put the radiator cap back on
Old Oct 4, 2006 | 11:22 PM
boostedeg9's Avatar
okay guys the car has a brand new pwr radiator, thermostat, waterpump, and headgasket. and the damn thing still heats up. the upper and lower radiator hoses become rock solid after 10-15 mins of driving. on of my friends said the cylinder might be cracked or the head is warped. what do you guys think
Old Oct 4, 2006 | 11:34 PM
wudini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg9 &raquo;</TD></TR><TR><TD CLASS="quote">okay guys the car has a brand new pwr radiator, thermostat, waterpump, and headgasket. and the damn thing still heats up. the upper and lower radiator hoses become rock solid after 10-15 mins of driving. on of my friends said the cylinder might be cracked or the head is warped. what do you guys think</TD></TR></TABLE>
im freakin out man...thats almost exactly like your original post. lol seriously though..
cracked cyl. is worste case, try all the things recommended. burp your coolant...compression test will rule out a head gasket issue.
Old Oct 5, 2006 | 08:31 AM
RED95EG6's Avatar
did you re-surface the head before putting new gasket?
Old Oct 5, 2006 | 08:45 AM
ciscoscivic's Avatar
sounds like a bleeding issue. any white smoke out the exhaust?
Old Oct 5, 2006 | 12:29 PM
boostedeg9's Avatar
Default Re: car over heats (ciscoscivic)
would a unproperly bleed system cause the upper and lower radiator hoses to be rock solid while the motor is running
boostedeg9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95EG1 &raquo;</TD></TR><TR><TD CLASS="quote">did you re-surface the head before putting new gasket?</TD></TR></TABLE>
no i didnt
Old Oct 5, 2006 | 12:31 PM
boostedeg9's Avatar
Default Re: car over heats (wudini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wudini &raquo;</TD></TR><TR><TD CLASS="quote">
cracked cyl. is worste case, try all the things recommended. burp your coolant...compression test will rule out a head gasket issue. </TD></TR></TABLE>
what should the comp numbers be across all cyclinders
Old Oct 5, 2006 | 12:40 PM
Ghetto Civic HX's Avatar
I love to drive
Not to thread hijack but...
Does the OEM thermostat have a bleed "screw"? The write-ups I found on HT and in my Chilton say and show bleed screw, but my thermostat has more of a peg that sort of dangles.
Old Oct 5, 2006 | 12:42 PM
poptik's Avatar
Default Re: car over heats (Ghetto Civic HX)
maybe the coolant seal
budget
41
Aug 5, 2005 09:11 AM
C M S
Jul 9, 2005 04:10 PM
130R
17
Dec 27, 2004 07:07 PM
fridexter
Nov 20, 2004 02:52 PM
