B20/Vtec, which map to build off?
Old Sep 25, 2006 | 10:34 PM
Ti3d in's Avatar
Default B20/Vtec, which map to build off?
I'm throwing in a stock block/stock gsr head B20/VTEC setup, and I was wondering which map to build off of. I was thinking about just using the P72 map, with adjustments to fuel of course, and possible just adding timing across the board? Right now I just need something that will run the motor safely and reliably until I can get it dyno'd.
Old Sep 25, 2006 | 11:11 PM
b19coupe's Avatar
Default Re: B20/Vtec, which map to build off? (Ti3d in)
Hondata? A P72 is a good place to start as it offers IAB control if you are using a GSR intake manifold. I would not add timing until you hit the dyno-don't want to kill the motor.
JDMswagSerf
Feb 7, 2016 02:50 PM
fv8s
Engine Management and Tuning
16
Oct 24, 2010 10:10 AM
ser13
Oct 28, 2009 07:11 PM
Hybridize
Jun 5, 2009 07:47 PM
ser13
May 29, 2009 05:31 PM
