96 Civic passenger window issues
My Civic has this annoying problem of the glass seeming to come out of the rails whenever I try to lower or raise my window. Is there any way to fix this problem? I was debating on buying a whole new set of manual doors but I dont feel like wasting money if I can fix this for cheaper. Thanks.
My car is an EX by the way.
You can try "greasing," or softening the rubber liner around the window. I have heard of people using a specific solution that Honda dealers sell that you squirt into the slits of the rubber that makes the window slide more easily.
-Shane
-Shane
Its not necessarily the "greasing" part that is the problem. Its more like.. when I took off my panel to see what was going on, it doesnt look aligned to go up underneath the weather stripping thing. It's hard to explain.
I fix it so it looks good and fits perfectly. But as soon as I lower the window and raise it back up, its messed up again.
Thanks for the input though.
Is the tract in the front part of the window tightened? There are 2 screws/bolts that can be adjusted so that the front tract doesn't move. Perhaps this is the problem?
-Shane
-Shane
hmm. I have to check that tomorrow when theres light out.
Do you have pics or a description where I can find these 2 screws/bolts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libero »</TD></TR><TR><TD CLASS="quote">hmm. I have to check that tomorrow when theres light out.
Do you have pics or a description where I can find these 2 screws/bolts?</TD></TR></TABLE>
No, it's been a long time since I've had the door panel off. If you do take it off, you will know what I am talking about. If you follow the front window tract down, you will find the bolts.
-Shane
-Shane
ChrisChuck
Feb 6, 2011 07:14 PM
dingobat
Oct 9, 2008 09:56 AM
KEVlN
11
Nov 11, 2005 08:36 PM
