need some help in drilling block (broke a sender unit in side...)
Old Apr 30, 2002 | 11:56 PM
94GSRRacer2's Avatar
New User
Default need some help in drilling block (broke a sender unit in side...)
Ok, I was trying to install an auto meter water temp guage inside my block today, and I guess I was stronger than I thought, and it broke off, leaving part inside the block. however it is not leaking. So i am faced with 2 solutions. 1.) drill current piece out and install a new one, or 2.) install a new one somewhere else, (some ppl say to install near thermostat, but i have no clue where that is....) can someone please help? I would prefer to take a drill to the old one, and drill it out any help is appreciated
Thanks,
Evan Richardson
Old May 1, 2002 | 07:45 AM
Crazydave's Avatar
Default Re: need some help in drilling block (94GSRRacer2)
just get some needle nose pliers or a pick
or vice grips and see if you can back it out
Old May 1, 2002 | 08:36 AM
GruvyTune's Avatar
New User
please go to your hardware store and get a reverse thread bolt remover.
You drill a small pilot hole in the object that is stuck then screw this thing with reverse threads into it and it tightens down and allows you to unscrew the item you got jammed in there. Usually works well.
Torin
lowkey
Nov 20, 2011 04:39 PM
ge_itr
Feb 3, 2007 01:20 PM
PhatBoy5015
Feb 22, 2006 05:59 AM
FMIDRC Racer
Feb 14, 2005 11:48 AM
McFly
Nov 10, 2002 09:10 AM
