ecu chipping
i have decided to get an ecu from rywire, i have a stock d15 vtec i am planning on doing a low boost turbo set-up in the near future, my question is what should i order when i get the ecu done vtec engagement...so and so what has worked for some of you guys and can i get the ecu chipped to work without an o2 sensor, i have seen these options on ebay chipped ecus thanks
We can customize the ecu if you wish, BUT when you buy a ecu as a basemap with boost, please dont boost on it. Its not 100%safe, each eng setup is different, and boost really needs to be tuned on a dyno.
